Member
Charge Temps
I know it's a bit vauge but what temperature would people expect to see above ambient in a decent intercool setup ?
.My twin cooler setup seems to work ,it has reduced the inlet temp at just before the throttle by some 6 to 8 c from the std GTA setup .
I was seeing temps of up to 46c on the std unit and it won't go past 38 on the double setup .The GTA is known to suffer with the heat though as the intercooler is at the rear of the engine
It's about 15 ambient and I'm runnng a std GTA T3 with a bigger exhaust housing at 10 psi .I need to check the temps at the turbo oulet.
Checked temps at the turbo ,90c peak @ 10lbs.
