I need all the tourqe settings for the engine . Any help would be great. cheers
haynes manual is your friend....
or if ur a lazy fecker.
main caps - 65Nm
big end caps - 45Nm
headbolts - 60Nm - but everyone does them to 70Nm
flywheel bolts -50Nm- must use loctite! - and i usually do em to 60Nm.
anymore?
Tea, strong, no sugar and some toast. Make it quick.
thanks for them buddy. i also need cam shaft pully bolt , crank shaft pully bolt and timing cover bolts if you have them
thanks
anyone?
cam pulley center bolt to 35Nm and bottom pulley center bolt to 110Nm.
Haynes manual doesn't fekin tell u and it tells you to put it back together wrong!
AutoData says 25nm run for 20mins then 65nm (standard gasket etc)
Mines been done a bit tighter as I have an uprated HG - as advised on here
many thanks scoff. now all i need it a timing diagramfor the base settings if anyone has one
are you using a standard pulley ?
you remove the tensioner, create equal slack on each side of the chain (pull it together in the middle) and the 2 liners or '+' on the cam and crank pulleys should point directly at each other. use a straight edge between bolt centers to verify.
no im using a vernier pully
