Im having trouble getting my megajolt running and im moving house. I decided to put the remix stuff back on so i can drive my car to the new garage. I had removed the plugs from the aei and cut the wires back so i couldnt connect it straight back again. I ran a 12v feed to the aei, a earth and a wire from the tacho and fuel pump pick up. I wired these in and then connected the tdc wires. I also wired the fuel pump relay back in .
I cranked it over but with no joy, i removed a plug and i dont have spark when cranking. I have 12v at the aei which ignition on though. The fuel pump didnt work either which makes me feel im not sensing the flywheel.
Does any one have the wiring instructions for the aei , as the 12v feed is a new feed from a 15amp fuse as i couldnt remember where the original one went. Also maybe for the fuel pump relay
Any i deas on no spark at all, i have checked drive gear and its correct.
thanks Hammy
