ARMTECH Rev Limiter mounting instructions
hi
I desperately need help! there is no one who has the installation instructions for the control of armtech rev limiter? Some if the sale includes instructions for mounting on Super 5 GT. But I can not find from any vendor.
Can you guys help me?
Best Regards
Sebastian
Re: ARMTECH Rev Limiter mounting instructions
First off you need to open up the renix to get at the coil, then take a wire from the positive side of the coil and the negative side of the coil, then on the end of the armtech unit its self there should be a plug with space for 4 wires. One connects to ground (negative) then the two wires off the coil go to there rightfull places, the other space is for attaching a wire for the full throttle shift via a clutch switch. Hope this helps
Download the instructions off the Armtech site......
