altenator
as i have just been forced to change the altenator belt i have fitted a new cable but the altenator does not go back to original position the belt is not to tight but if i put it back to where it was the belt would have no slack at all will this be ok.
Motech
Re: altenator
i'd rather it be a lil tight than too loose, too tight isnt as serious as too loose. I do mine pretty much as tight as i can get it(obviously depending on what implement your using to tension the alty lol)
Motech
Re: altenator
Too tight and it will wear it out quicker, too loose and it will slip and wear out alot quicker, possibly jump off and possibly slip on your alty/water pump, not cooling and not charging properly.
