Ok im getting the battery light flickering. This only happens on part throttle, when its idling its fine and when your at wot its fine. Belt is tight, no squealing. Sometimes idle moves from just under 1000 revs to 700 when you come to a stop after a blast. Speedo is a bit lazy sometimes when the revs drop too. Do you reckon its an alternator problem or an earth problem, or something else? Cheers Chaps
