Scoff
the paint from a rattle can is pretty soft usually, g3 would be overkill. try the following:
find some 2000 grit paper, bucket of clean soapy water, soak the paper and the filler cap then lightly 'flat', or rub the orange peel away. be carefull, you'll rub through the paint quicker than you'd think, literally just take the tops off the orange peel. pay attention at edges, not to rub through.
with a damp cloth give it all a good polish with tcut or some other mild cutting stuff and it should come up nice.
if it was a metalic then you might have needed to laquer it before doing the above, but sometimes the metalics out of a can polish up OK without the clear.
