Committee member
Rats Nest Tuning
Flywheel studs???
Would it cause problems fitting the clutch to the flywheel wthout fitting the 3 locating studs?
Reason: spelling
Trader
Re: Flywheel studs???
yes...they take the main brunt or torque from the plate to the flywheel.....
the bolts are to secure it, the dowels take the twisting force
Committee member
Rats Nest Tuning
ahhh bollox, so i shouldnt run the car without them? can you get them from reno?
Trader
I wouldnt but its your choice...
7703067268
but all flywheel studs are the same, 5,19,clios etc.....
should be able to pick them up easy enough locally ....or mole grips and a breakers yard
