hose connectors for oil
im assuming i cannot use the barbed nylon type hose connectors with oil cooler pipes.??
im basically after a pair of 90deg bends to route the oil cooler pipes but am unsure what material to use? steel? brass? copper?
ive had a quick look on ebay but im unable to find any 13mm/0.5" 90deg bends! can someone help me out with this pls
Member
Re: hose connectors for oil
thanks for that, ill give them a shout
ive had a change of plans, i now need a pair of flexy/silicone type elbows?
question is,is it absolutly nessesary to use fluro lined hoses for oil.? as i cant find any 12mm/13mm fluro lined elbows
