Results 1 to 3 of 3
    Non-member allanr5gtt's Avatar
    Dec 2008
    the carport
    egt probe
    hi all
    i have a 3b1 tec edge wide band that can have up to four thermocouple inputs. i'm thinking of using one for each cylinder.
    is a thermocouple the same as a egt probe?
    what sort of temps should you be getting?
    i have been looking for these ones
    http://tscsensors.com/egtep0720001ssnexhau.html
    any info would be very great full thanks allan
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: egt probe
    Hi allan, they'll be slow probes at over 4mm tip diamater. A good probe will be 1.5mm or less at the tip.
    Non-member rs250nut's Avatar
    Re: egt probe
    To true mines not alot of use unless driving really hard for long periods of time.
