Results 1 to 9 of 9
    Non-member Slim's Avatar
    Sep 2009
    NW London
    why is it smokey?
    Hi guys..
    need your opinions please.
    My 5 smokes blue (oil) a little.. when just started. The warmer it gets it smokes more until its fully warm.. then seems to stop. While driving it seems fine. Just dont like all this smoke when i have to start and warm her up.
    what could it be?
    thanks
    Non-member Big Supes's Avatar
    Southampton
    Re: why is it smokey?
    Sounds like the valve stem seals aren't doing their job anymore to me.
    Non-member hydrotec78's Avatar
    Hartwell
    Quote Originally Posted by Slim View Post
    Hi guys..
    what could it be?
    thanks
    It sounds like it could be the rings your having problems with as valve seals would always leak if there gone, but when the rings warm up they expand to feel the gap.
    when you first start the car dose it breath at all out of the oil cap?
    Sep 2009
    NW London
    Quote Originally Posted by hydrotec78 View Post
    when u say 'breath out of the oil cap' do you mean does it smoke out of there? I shall check... but what am i looking for? p.s i also have a catch tank so will check the that too wen i first start it.
    If its the rings... is there anything i can do? other than rebuild it!? any thing i can put in the oil?
    Sep 2009
    NW London
    Quote Originally Posted by Big Supes View Post
    thats wat i thought....not sure... mite wait till it gets worse..
    Oct 2009
    Stoke
    There are additives you can buy but they can only do so much. To be fair, I would get the bottom end done. Doesnt cost much if you can do it yourself. Iv just done an engine rebuild for my project and bought new piston rings and had the liners cleaned and honed. The rings were £60 and the honing cost me £20. It might sound like a hassle but at least the jobs done properly plus you dont want the rings breaking up when your driving!!
    Non-member Adam 005's Avatar
    Dorset
    Sounds like valve stem seals to me.If you let the car over run down a hill then pick up the thottle at the bottem does it puff a load of smoke out.
    Worn rings tend to cause smoke at all times.
    If you have any worries do a compression test
    Dec 2004
    Aylesbury
    As Adam says do a compression test to see what it says, will eliminate weather its to do with rings or liners. Also do quick test like Paul says, take oil cap off and see if you got pressure coming out of the oi cap.
    To me does sound like worn valve guides and not just the seals, but do check anyway mate.
    Southampton
    If it's bothering you that much, I'd be more inclined to do a leakdown test over a standard compression test.
