Results 1 to 10 of 10
    North East Regional Rep HULK's Avatar
    Aug 2009
    harrogate, North Yorkshire
    Help with wiring up a perc fan via a switch
    Ok chaps before i start, I know the pros and cons of anti perc fans, I know what they do and what problems they have caused people etc etc......
    Ok basically I dont have an anti-perc fan as its been removed and i want to put one back on, but i want to wire it up to a switch so i`m in full control of it,
    I only intend to use it for short periods eg, at petrol station.............
    ie, This is what i want to achieve........
    1, pull up at petrol station, turn engine off, switch fan on
    2, fill car up with petrol, go pay for petrol and sweets etc
    3, walk back to car, get in, switch fan off, car starts first time
    4, mates and onlookers dont
    5,I dont feel as no-one has taken the piss out of it taking ages to start
    ok what do i need to do this and how and what is the best way to wire it all up??
    obviously I need a perc fan, switch, wiring etc, what else do i need, any relays or stuff???
    I`m only wanting the fan to blow cold air on the base of the carb etc, not bothered about blowing down pipes as well.
    any help would be greatly appreciated
    Jim
    Non-member markey b's Avatar
    Bury St Edmunds
    Re: Help with wiring up a perc fan via a switch
    it seems like alot of hassle for minimum gain chap
    i always bin the perc fan and have no issues with hot start on my tuned orange one, or my standard raider, both start with no choke from cold and both hot start after a couple of turns of the starter...
    bit of throttle and maybe a couple of primes of the fuel pump and you shouldn't have any hot start probs
    Non-member Adam 005's Avatar
    Dorset
    Leave it in the bin chap
    Non-member tonesGTT's Avatar
    Aug 2000
    Can anyone actually tell him what he wants to know though
    Bury St Edmunds
    yeah sorry... its exactly the same princple as wiring up a cooling fan switch
    i'd run a perm live to a switch, then to a relay, and then across the relay run the fan positive if that makes sense... i'll try sort a diagram
    Bury St Edmunds
    or, if you've got an aftermarket alarm, use a timed relay off the locking pulse for your central locking so that when you stop and lock the car it'll kick in
    Aug 2009
    Cheers Markey, Diagram would be cool, as basic as possible, just to a switch would be fine, do I really need a relay or can i hook the fan straight up to a positive and negative via a switch etc??
    Bury St Edmunds
    red is 12v permanant feed, from battery + or alt + terminal, via a fuse!
    green is to chassis earth via your switch
    blue to + of fan motor
    then earth the other wire for perc fan
    Aug 2009
    Cheers pal your a star!! very helpful indeed,
    now who has a spare perc fan they want to sell me??
    Bury St Edmunds
    i may have one or two
