GTT Dashboard
I just wondered if there were any differences between the non GTT and GTT dashboards, i currently need to replace this section due to damage and was wondering if i could use a campus section?:
Loose Bolts Tuning
Re: GTT Dashboard
yes mate, the dash is the same as other model R5's, including campus models.
But the section you have removed (above the heater box) is bonded too the rest of the dash (plastic spot welded anyway) so you will struggle to seperate the part you want from another dash withou damaging it as well. While you are at the stage you are, you may as well just remove all the dash and replace it with the new one.
Re: GTT Dashboard
Oh dear. Thats what i'll have to do then. Thanks very much for the advice
