Headgasket?
i suspect my headgasket is on its way out, wot do u recon?. This is only cos iv seen "custard" in the crankcase breather hoses, although theres no obvious water in the oil, no overheating, no white smoke from exhaust. i figured it might have a small leak as the crankcase breather system must be venting off water vapour. Am i right? not sure so any info would be much appriciated.
Re: Headgasket?
ive just had a look in my oil seperator pot and there is some mayo in there,
but as you say none anywhere else at all , i put it down to moisture getting in there i hope anyway
Re: Headgasket?
lol hope not. Ive had a look at a few of my friends and they had none so thats why i posted to c if i could gather a bit more information.
Re: Headgasket?
Take all the breather system off and give it a good clean, remove all the mayo in there and se how it goes. It could be condensation build up or crap from a previous problem thats not been cleaned up.
Re: Headgasket?
woz thinking about it, gota be the best way. cheers fella
