im going to be fitting a pair of morette twin headlights soon and was hoping someone could give me instructions on fitting them? or is it simply a case of removing the oe headlamp then fitting the morettes and pluging the wiring harness in situ.?
Also i plan to fit a H.I.D conversion kit.! does this seen ok ->
http://cgi.ebay.co.uk/Hid-Xenon-Conversion-Kit-H4-HI-LO-BI-XENON-6000K-55-W_W0QQitemZ160287884974QQihZ006QQcategoryZ72235QQs sPageNameZWDVWQQrdZ1QQcmdZViewItem
question is, how would these work.? would the h.i.d only work on the outside lamps? i dont plan on using the inner lamps anyway.
sorry to sound silly but get confused of which low/high/dipped beam is so....... would i still be able to use dim beam with 1 turn of the stalk and then bright beam with the second turn? also will i still be able to use flash by pulling the stalk..?
