gear box
can some 1 put an article up on how to adjust gearbox selector / forks thanks
Honorary Member
Re: gear box
the forks are not adjustable but the leaver is
if it wont go into 5th adjust the leaver to the left a tad
if it wont go into rev adjust the leaver to the right
if it wont go into rev 1st 3rd or fith adjust the leaver the the rear
if it wont go into 2nd or 4th adjust the laver foward
if its like a sloppy pig in mud , sort out the pivot point under the box
East Midlands Regional Rep
Re: gear box
The easyest way I found to do it was make sure it selects reverse and the rest should be spot on
Re: gear box
cheers but i can select all the gears but it has started to fall out of second an some times forth so would say its a bit like a sloppy pig in mud
