Results 1 to 10 of 10
    Non-member Leigh's Avatar
    Kent
    How can i tell what jet...
    How can i tell what jet's ive got in my carb ? Is there a number stamped on them somewhere ?
    Thanks Leigh
    Trader paul b's Avatar
    Jul 2002
    Re: How can i tell what jet...
    there should be a number stamped onto the jet.....
    but that does not mean it has not been drilled out to a larger size
    Kent
    Bugger ok, is it better to start again then because looking at the other bodges ive found better to be safe than sorry. What jets would you advise ?
    Leigh
    Jul 2002
    if you pop a list on here of your engine spec, turbo ...expected PSI etc then i am sure someone may help...
    Kent
    cheers. Its a BB Tuning Yellow spec with a T25 Gen 4 running approx 18psi
    Also where do i get them from apart from Renault dealer as local one is rubbish
    Kent
    Can anyone help with what jets i need please ?
    Banned
    Weymouth
    k-tec web page has them on and the air correctors mate
    Non-member UNICRONICUS's Avatar
    Jun 2004
    Isles of Scilly
    Southern carbs sell jets for the Solex 32DIS.
    Non-member Dicey's Avatar
    West Midlands
    Quote Originally Posted by Leigh View Post
    Bob at http://www.cgbmotorsport.net/ is always helpfull mate.
    Its hard to advise jetting, as every engine/spec varies. What works for one might not for another.
    Id be looking at buying a wideband afr gauge if you haven't already to monitor fuelling, start from standard jetting & develop from there.
