Results 1 to 10 of 10
    Aug 2009
    North Herts
    Stuck in gear
    Right. I know my engine mounts are in need of renewing (which I was going to do tomorrow actually). It jumps out of gear in 2nd and 4th. I gave it some lemon earlier and it the gear stick got jammed in 2nd, eventually i was able to whack it out. Then it drove okay in every gear as before. Parked in Tesco's, get back in to car, start it and it was stuck in gear and I couldnt move the gear stick anywhere other than the reverse position (which made the car drive foward?). Anyway, it was stuck in 3rd I think.
    Could this be an engine mount issue, as I know the nearside front mount can cause selection probs.....or do you reckon I have a mullered box?
    I am extremely experienced with these cars, but before I get up and fiddle with it tomorrow I want to know other peoples opinions.
    Also, what way would you try and get it out of gear?
    I really can't be arsd to take the box out/split box or anything.
    Merci!
    Re: Stuck in gear
    Disconnect the gear selector from the gearbox and see if you can get all gears.
    Non-member IANMM's Avatar
    Sedgley
    Re: Stuck in gear
    read this and do what was said earlier about disconnecting the selector rod first
    https://www.rtoc.org/boards/showthrea...=gear+selector
    Non-member philr5t's Avatar
    Dec 2008
    tadworth
    Re: Stuck in gear
    mine used to do the same mate if it was in gear then you backed off the gas and then back on the gas it would jump out of gear. It eventually got jamed in 5th when i released it i could then only select 2nd and i think reverse. I found the fault with box and it was the nut that holds 5th gear on it hand come loose and allowed 5th gear to move backwards and forwards, and as i selected gear the fork had got wedged between the gears and ****ed them what i would say is just take the black end cover plate off that is where the nut is for 5th gear and check if its loose before stripping all the box down as this could be the problem
    Aug 2009
    North Herts
    Re: Stuck in gear
    Quote Originally Posted by philr5t View Post
    I've had this bofore, a long time ago. The symptoms are different this time round.
    Non-member LYNCHSTAR's Avatar
    Re: Stuck in gear
    Quote Originally Posted by trojan View Post
    Merci!
    hello there mate my box was doing the exactly the same thing mine was getting stuck in second when i thrashed it in that gear only and it was a right sod to get out one day i wacked in into reverse and it would not come out. i ended up changing the gear box. i held the old box up and gave it a shake in herd something inside it was dead.
    Aug 2009
    North Herts
    Re: Stuck in gear
    Mine turned out to be knackered too. The gearbox oil was more like silver paint!!
    Non-member mr bean aka pete's Avatar
    Jun 2006
    oxfordshire
    Re: Stuck in gear
    have you had gearbox problems with this box b4 ? ie: selecting gears popping out of gear ? if you have had problems it may have given up the ghost and be dead sounds gearbox related have you ever checked gearbox oil level ?
    Aug 2009
    North Herts
    Re: Stuck in gear
    It is the gearbox.
    Re: Stuck in gear
    so was mine the oil looked like silver and grey matalic paint.
