Currently running in my car after rebuild,
So far done 60miles with just a few minor probs odd oil leak etc. Went to go for a drive in it tonight and it will not idle every time you come upto a junction it stalls revs just drop.If it does idle its rough and gets lower and lower until it stalls. It has been like this from cold, and when its warmed up.
When its running it drives ok apart from feeling a little hesitant.
The past couple of days its been fine.
The carb is fully refurbed and was running fine.
Ive cleaned the idle jet.
Removed DV incase that was leaking
What else can i do? is it worth adjusting the idle?
