Results 1 to 6 of 6
    Non-member Schakal's Avatar
    Barry
    blocked bleed nipple
    one of them bleed nipples on the rear (drum brakes) seem to be blocked
    and obviously got to get it out for inspection and cleaning .
    am i right thinking there wont be much fluid loss if i wrap
    some cling film around the lid of the reservoir ?
    Re: blocked bleed nipple
    As soon as the bleed nipple is loose the fluid will start dribbling out, clamp the flexi hose to minimise it.
    Non-member BriC's Avatar
    Dec 2005
    Muahahahahaha.. You said nipple!
    Honorary Member RichR's Avatar
    York/Selby
    Agreed - clamp the flexi hose. I've got a nice plastic brake hose clamp (looks like a pair of pliers with a locking bar between the handles) that won't damage the hose. Once you clamp the hose, you can remove the pipe from piston and only lose a few ccs of fluid.
    Barry
    thanks for the replies
    i have not got special clamping tool ,but i guess a pair of locking
    pliers will do the job if i wrap something around the hose to take the
    abuse from the teeth of the pliers ,yeah ?
    Non-member Billy-G's Avatar
    Feb 2002
    It changes. A lot.
    Quote Originally Posted by Schakal View Post
    What I use.
