Results 1 to 6 of 6
    Non-member TNT!hammond's Avatar
    Norwich
    .64 ar
    just trying to see if anyone who runs a 60 trim with a .64 ar has any feedback to give me
    basically im debating if i should buy another .49 rear or buy a .64 housing for my t28 non roller bearing turbo .
    I have room in my life for a little more lag but dont fancy waiting till 6k for 20 psi lmao. I have room high up for peak power to be made later too as its only made at 6-6200k so thats ok. Car is used on the road but i did build it mainly for track . msm cam so plenty of lift and what not .
    Any help much appreciated as normal
    ta , hammy
    Non-member 5teve L's Avatar
    RH12
    Re: .64 ar
    When you say track, do you mean drag or trackdays ?
    I think Rob @ Backyard used a GT28r at some point on the drag strip, pretty sure a couple of other people tried it as well.
    Non-member GTphil's Avatar
    Re: .64 ar
    The turbo I run has a .64 ar but is smaller than a 60 trim, I get full boost at just over 4k/4.5k depending on how much and I have a piper 285 cam, so with a 60 trim I should imagine you will get boost quite a bit later than 4k. the .49 ar is really the ideal option
    Mar 2004
    Salford (manchester)
    Re: .64 ar
    Im on a .64 (GT2560r)
    Mar 2004
    Re: .64 ar
    I wouldnt go that big tho for a track car but its not that lazy imo...
    Norwich
    Re: .64 ar
    hahahah oh well i ordered it this morning so now i have 3 options to run. .47 .49 and now a .64 . ill have a go with them all
