Results 1 to 14 of 14
    Non-member markey b's Avatar
    Bury St Edmunds
    after a quick and easy fix please
    right, raider of love has one niggle, when you accelerate, it hesitates before it goes.. if the choke is out, its ok, but without choke it seems to hesitate when you press the accelerator. ive changed the acc pump diaphragm as that was leaking, but still no change.
    just wandering if anyone has had anything similar in the past, and if so is there a quick fix so i dont have to spend hours out in the cold
    Re: after a quick and easy fix please
    Sounds like the ac pump arm needs resetting. The old 5mm drill bit jobby
    Bury St Edmunds
    thank you james, not the quickest fix but i'm sure it'll do the job
    Non-member Spooky's Avatar
    Sep 2001
    SW PMT HQ
    is the carb standard?
    also do what James mentioned
    Bury St Edmunds
    i've not had it apart to check jets, but as far as i'm aware its standard
    car only runs up to 11psi, but it doesn't even need boost to missfire. just annoying as driving 'fast' isn't as fun as it should as you can pull smoothly out of corners without it jerking like muhammed ali
    Sounds like it is the accel jet Mark, it will be blocked. It's that funky hooked thing that squirts fuel straight down the venturi. Checking it, and if duff removal and refitting, is very easy.
    Gives very annoying hesitation everytime you put your foot on the accelerator if it's blocked
    Get a new one if poss. Not sure how you'd unblock something so piddly thin.
    Oxfordshire
    yup, engine off, remove carb elbow, look into the top of the carb and watch what happens when you open the throttle, it should be a nice squirt through that jet down into the venturi, and not dribble around the edges. If it looks OK, do the 5mm drill bit jobbie
    oh, and the linkage can seize, so you might need to free that off, pretty obvious when you look at it.
    Classifieds Moderator
    this is exactly what mines does, someone said about sorting it in someone elses thread but i've still not got round to it..
    i'll have a pop at mine later too
    Thanks Andy.
    Bury St Edmunds
    thanks guys, i still need to take a look, but at least i know what to look for when i finally get me arse in gear
    Non-member Logg's Avatar
    Could someone please explain the "5mm drill bit jobbie" set up, as my poor old 11 suffers with this hesitation problem!
    Non-member LYNCHSTAR's Avatar
    What's the 5mm drill jobby mean. What do you do.
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    with the carb removed, slide a 5mm drill bit inbetween the throttle plate and venturi wall and then adjust the acc pump arm.
    Bury St Edmunds
    Quote Originally Posted by raj View Post
    my problem is motivation, until the raider stops working i find it hard to do jobs on it, usually let them build up and up then have to spend a cold evening out on it
