Results 1 to 13 of 13
    Non-member *Yellow*'s Avatar
    Driveshafts
    After destroying the cv joint on the n/s driveshaft during my last race.
    Can I get a new cv joint put on the shaft as its been shortened due to the Gripper diff. If yes, does anyone know of any companys London area who could do the work.
    If not I guess its new shaft and cut to size again.
    Many thanks
    Dave
    walsall
    Re: Driveshafts
    i had mine done on the evo but forgot where in brum they was
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: Driveshafts
    the outers are pressed on a spline. the shaft is hollow, the cv has a spline comming out of it that is pressed into the hollow shaft. I think you'd have to heat it off. Never tried, but I know it's do-able.
    Re: Driveshafts
    Cheers Guys, found a driveshaft place locally today, so going to take it there Monday and hopefully they can sort it.
    Non-member Mudslinger's Avatar
    Feb 2003
    Re: Driveshafts
    ive had the cv joint replaced 2x now on my shortned shaft , local guy does it for £20
    Re: Driveshafts
    Quote Originally Posted by Mudslinger View Post
    You`ve had a result
    Went to see guy today, not interested as was everyone else spoke to.
    Non-member Arrows's Avatar
    Apr 2004
    West Sussex
    Re: Driveshafts
    Why not send the shaft to Mudslinger and get his man to do it and bung mudslinger a drink for his trouble, just a thought.
    Feb 2003
    Re: Driveshafts
    Thanks Mud, will give them a call.
    Non-member olidaviesuk's Avatar
    Nov 2008
    Bromley
    Re: Driveshafts
    Have you tried london props, are over in wimbledon, one of my mates had some shafts done over there for a 2.0litre nova a few years ago... might be worth giving them a shout
    0208 542 2155
    Quote Originally Posted by CLARKY View Post
    Many thanks
    Dave
    Ivybridge
    Re: Driveshafts
    Many thanks
    Dave
    Have you got rack stops in the ends of your steering rack? I know they were/are a common method of reducing the likelyhood of high torque from the spider cracking the yoke, as they don't let the spider get too close to the end of the yoke in it's weak spot. Having said that I am not sure what size they turned them too for the cup cars, I'd guess 10-12mm, but the manual doesn't mention them.
    Oct 2007
    costa del walney Island NW
    Re: Driveshafts
    At a geuss why should Cv joints break.
    1 - no grease
    2 - bad engine mounts
    3 - ??????
    I have had 1 fail due to split cv gaitor, and i belive i shafted another not long ago due to engine mounts worn and old.
    Any other thoughts any one ??
    Non-member Adam L's Avatar
    Feb 2003
    SW London
    Re: Driveshafts
    Bearing in mind, Dave's car is a full on track racer so has constant wear and pressure on the front end components.
