Results 1 to 9 of 9
    Oxfordshire
    F series water pump longevity?
    I'm poking about the 172 lump looking for things that may need changing. The water pump feels worn to me, slight play in the bearing, and it spins quite freely. It's a 2002 lump with just over 70K on it. My instinct says to replace it whilst the engine is on the floor, opinions please...
    Andy
    Kent
    Re: F series water pump longevity?
    .....yep I would....saves alot of fwaffing about in a tiny engine bay......
    Non-member Schakal's Avatar
    Barry
    same pump as all f series engines ,here is a cheap one
    http://cgi.ebay.co.uk/RENAULT-CLIO-1...lenotsupported
    I dont think thats the same as the F4RT. Andy is the 172 cam belt driven?? Get some pics up for a butchers
    Yeah the water pump on the 172 f4r lump is cam belt driven I think there are some pics of my setup in the technical section under my folder
    Oxfordshire
    Trader paul b's Avatar
    Jul 2002
    no brainer............get it changed....
    if you havent already , timing belt and tensioners....
    alternators usually good for 70k but not much more...
    cam variator....app 70k miles
    and always carry spare pencil coil's....
    Non-member boostjunky's Avatar
    Nov 2008
    London
    You're worrying me, my 172 Cup is about to hit 60k. My F4R has a coil pack ignition as well.
    Oxfordshire
    belt and tensioners are pretty fresh, as is clutch, and I think flywheel.
    cam variator feels tight, I'll know better when I reset the timing.
    it's coilpack, so that's a bonus.
    I'm ordering wishbones and trackrods in the morning, so will add a pump onto the order
