Best Camber setting
Ime taking the 5 in for a alignment check.set-up next week and will be fitting a set of camber correcting bolts, Any idea of the ideal camber adjustment? i think there's only 3 deg to play with, just didn't want north eastern giving me a blank look
Trader
Re: Best Camber setting
if your on the road or track its all different....
are you after an aggresive turn in but 5000 miles out of front tyres,bit of a handfull on back road fun.set for track ....
between 1.5 and 3 degrees of negative camber
or nice and easy on normal roads,no big surprises on back roads....normal tyre wear..
standard settings which they already have
Hehe only 3 degrees I ran 1.5 degrees on my classic mini, seemed a good compromise for on road and track
I run the cup numbers on mine. Makes it quite fun
http://membres.lycos.fr/r5gt/gtt/cup.htm
