ok so my running lean problem may nearly sorted....
ok,put a post up ages ago,saying the car runs lean after 10 seconds'ish on boost,like the carbs emptying too fast. changed and cleaned everything on fuel side....still no use.
now,iv checked pump voltage,constant 14volts,checked pressure,4psi idle, 4psi above boost pressure on boost....but still leaning out after 10seconds (car holds back and afr's rise from 12.1 to 14-15-16)
so guessing its a carb thing....but what do i need to do? stripped and cleaned it twice now,do i but a "group a" or a recon standard one ?
help!
