Results 1 to 49 of 49
    Bedfordshire
    Cooling pressure issue's........
    Rite first off i re built my engine due to blowing the head gasket from what appeared to possibly have been from a previous problem, i've had head skimmed beautifly through marky mark contact and was all clean and lovely. Put it all back together fired it up and water was pissing out between the turbo and turbo elbow, and the rad hose's go rock solid within seconds. I am just wondering could a cracked piston liner be the cause of this ??? I did wonder if it was down to me cocking up putting it back together but am clutching at straws lol !!
    Any suggestions.........
    Non-member Schakal's Avatar
    Barry
    Re: Cooling pressure issue's........
    sounds to me like compression is leaking in to the water ways causing
    them to go under high pressure which will eventually blow coolant
    pipes etc .
    i would do a compression test to find out the offending cylinder/s than take it
    from there .
    Bedfordshire
    You think the compression could be leaking in from a cracked liner ??
    Barry
    Quote Originally Posted by Big-_-Steve View Post
    sorry never dealt with wet liner engines , on f type renault engines
    it leaks from the fire ring into a water way causing it to over pressurize .
    assuming you got a new gasket and its not yet buggered ,anywhere close to
    a water way on the head/block is a suspect .
    Bedfordshire
    Ok cool i'l get a comp test done asap !!
    Loose Bolts Tuning stuTHC's Avatar
    Dec 2005
    Leeds
    A crack liner would cause the coolant system to pressurise, so could an incorrectly fitted head, or even poor liner protrusions.
    How does it sound when it's running? It'll sound terrible if it is a cracked liner.
    Comp' test is the next step fella
    Leeds & South Yorkshire Area Rep
    Loose Bolts Tuning
    Robbo's Avatar
    brighouse
    stu thc knows all about this
    Loose Bolts Tuning
    Robbo's Avatar
    brighouse
    will it even run with a cracked liner?
    Dec 2005
    Leeds
    Quote Originally Posted by Robbo View Post
    Depending on the size/position of the crack, yeah, very rough thou, it's all about where the crack is
    Bedfordshire
    it runs ok not to rough but the pressure build's within second's !!! Is it worth taking head off then bolt it down again n see what happens ???
    No you can't really do that mate as the gasket is already compressed and ou can't do it a second time, if you remove it it'll be another head gasket.
    It be honest i'd remove the head anyway and have a look, if your not enitrely sure what everything looked like before i'd check it all.
    Non-member Nick k's Avatar
    Leicester
    Is it possible that the dow pin is not allowing the head to sit down proberly on the block due to it having a slim. If its pressurising in seconds i doubt its a liner cracked, points more to head gasket issues.
    Non-member TrixNFlix's Avatar
    Preston
    Quote Originally Posted by Tarmac trasher - Nick View Post
    I reckon you would of noticed the head not sitting right when the gasket was put on, but you never know, come on lad time to whip your head off!
    Preston
    Also to note my header tank was pressurising itself instantley when engine was switched on, 20 miles later this happenedhttps://www.rtoc.org/boards/showthread.php?t=8026
    I would do a compression test first, then if somethings not right head off time.
    Bedfordshire
    AHHHHH MMMAAANNNNN !!! Looks like im gonna have to get dirty lol what bout head bolt's will i have to replace them again ??? oh any 1 got a up rated head gasket going cheap lol
    cheers for all the tip's btw people
    I can get you a headgasket pretty quick mate if your in a rush for one.
    I dought its the headgasket as you haven't even driven the car yet, i'm sure it'll be something stupid or quite obvious.
    Bedfordshire
    Thats the only thing i can think of buddy cause there's no other water feed to the turbo or the manifold etc !! i'l leave it together so you can have a look then go from there because i don't wanna take it apart for nothing.
    How you mean no other water pipe to turbo?
    Yeah leave it as it is and i'll pop over and have alook mate
    Bedfordshire
    ya know theres the water pipe that comes from the water pump kinda area to turbo then back i've looped it so it don't go to turbo
    Non-member RICHIE's Avatar
    Jan 2004
    BEDFORD
    why not take the spark plugs out and see if there is water present try cranking it if need be.
    Non-member scratcher's Avatar
    Milton Keynes - ish
    I'll back down with my cracked liner worries as it sounded fine putting it back in the garage.
    I well hope its something simple
    Leicester
    Steve, Are we talking about the raider here that you need working for next weekend??
    Leicester
    Forget that?? different big Steve lol
    Non-member markey b's Avatar
    Bury St Edmunds
    i made it from the pod to the bp on the A45 with a cracked liner, just drove it turning it on and off and coasting alot!
    Bedfordshire
    Rite people here's an update i took out plug's spun it over and it spat water out on number 2 cylinder (from rite to left)
    If ya read this marky mark it's the 1 where it had been pinkin the head and the piston etc i replaced if this helps with any diagnostic lol
    Preston
    so are we thinking it's not fueling right for this piston?
    If so it's probably the headgasket gone and not the water ways cracked in head or piston liner
    Preston
    One of the big cheeses will have to tell you why it looks to be underfueling on that cylinder again. I don't know enough About this subject.
    Preston
    But I do know that you may aswell start taking the head off to look at it and the headgasket while you wait for the big cheeses to reply.
    Bedfordshire
    Rite yet another update, took plug's out and it fired water out like a water pistol lol but there dosen't seem to be any obvious signs of fault oh and remember the car hasn't actually been drivin since re build.
    Bedfordshire
    Heads off and can't see anything obviously wrong so think am gonna put it down to my stupidness lol !!
    Jan 2004
    BEDFORD
    have you taken the liner out then and inspected it closely have you checked your liner protrusion.
    Bedfordshire
    well from what i can see of the liner it look's sweet, and am guessing you mean do the liner's sit flush cause i didn't check lol is it a case of putting summit flat across em to check ?
    Preston
    Yeah the liners are supposed to be stacked like steps, for the best clamping force. Also check to see if their is much protrusion between the liners and block
    Preston
    U should also be able to check the headgasket to see how even and well it clamping down on the block and head. I.e check that the indentations are even at the front and the back.
    Bedfordshire
    So do you mean the liners should sit a little bit up from the block kinda thing ? cause all mine sit pretty much flush. and i know it won'y be exact kinda thing but is there usually a tiny bit of back n forth play in them ?
    Jan 2004
    BEDFORD
    run a striaght edge accross the liners see if that one sits lower that the two either side of it mate.
    Salford (manchester)
    get some pics up aswell if poss.....
    Bedfordshire
    I put a sraight edge across and couldn't really see any kind of gap..... is it gonna be easier to take em out and put new liner seals in ?
    So basically 2 of the liners will sit slightly higher than the other 2 ?
    Jan 2004
    BEDFORD
    the should be like a set of stairs mate not one up two down ect . i have liner seals if your stuck i did say i would pop down. scratcher should also know by now hes watched me a few times get him over. before you fit the seals though put them in situ without them and check protrusion
    Bedfordshire
    Oh rite i get it now so 1 is bit higher then the other 3 go bit lower each time ? your working away though ain't ya ? i'l have the seals off ya cause am guessing i need to do that as they don't sit like that at all lol.
  41. #41
    Jan 2004
    BEDFORD
    if they dont step correctly this could be your problem then fella. take out all liners and start again from fresh if you send me your address i will get the mrs to post the seals as im away at the moment.remember put them in situ without the seasl fitted and measure protrusion first.
  42. #42
    Milton Keynes - ish
    I'll help ya the best I can Steve. Richie showed me a few tricks
  43. #43
    Bedfordshire
    Coolio gangster !! think am gonna be taking bottom end apart now so can change the seals cause i think it's clear they need doing !!!
  44. #44
    Bedfordshire
    I HAVE POSSIBLY FOUND FAULT !!!! After going out and taking another look with a fresh set of non sleepy eye's i discovered a crack in the liner !!!! i would put pic on but dunno how to lol
  45. #45
    Bedfordshire
    All i need to suss out now is why it keep's busting that 1 particular liner !!
    Ang suggestions.......?
  46. #46
    Jan 2004
    BEDFORD
    how many times has this liner cracked then
  47. #47
    Bedfordshire
    it's only cracked it once but last time it burn't piston out and scored liner
  48. #48
    Jan 2004
    BEDFORD
    is the piston 2 by any chance mate from flywheel end
  49. #49
    Bedfordshire
    yeah buddy !!
