ok ive had alook but not sure how it is removed so could do with direction as it doesnt work and im getting a working one off raj
thanks
thanks
the bracket holding the fan motor in place is bolted to the top of the wheel arch. disconnect the relevant hoses and pull it out. Its fairly straight forward from memory. Putting one back in is a bit of a pain in the arse though
its bolted down on the wheel arch and also at the side of the suspension turret, i cant remember if your fuel line is running through it as originally the fuel line runs up through the plastic part of the perc fan and comes out where the air would hit the carb. if its like that then disconnect the fuel line.
also undo the hose that connects to the perc fan and plug it if our going to drive the car.
Don't forget, once removed you have to dispose of it in RTOC ordered fashion, namely throw it on the ground pour on petrol, set fire to it and dance around its satanic corpse to black sabeth
I like my anti perc fan!
Pretty sure thats why mine starts on the button, even when hot. Same as my Starter motor heat shields. I'm sure thats why my starters las years, not months
i hate the damn things, ive always got rid of them. never had any issues. maybe because ive got a habit of pumping the acc pedal a few times before i fire it up!
i dont know why i do this but i do it with every car i drive
