On the J plate R5 i have brought the rear brake compensator appears to be ziezed. Is it usually possible to free these up, or is it a case of buying and fitting anotehr one?
i bought a new one yo!!
I completely soaked mine every night for a few days in wd 40 and it its ok now so its worth a try
Buy this: http://www.bilthamber.com/deoxc.html
Bung it in. Leave overnight. Rinse off. Job done.
how much is a new 1 ? £1000 ?
it depends how long its been seized for. if your going to have a go then soak it in wd and just try and work it little by little. it should free up, mine did, but bear in mind if it breaks youl have to get a new one.
£130 abouts...treat urself buddy
There is only one out of the two that were produced availible. One had one coil in the spring to the rear beam and the other had 2/3 coils in the spring, its the one coil version thats unavailible.
I say this with great confidence , but i looked about a month ago and couldnt find the one i needed, using all the parts suppliers that i know and brakeparts.co.uk.
what is it that actually siezes up on it. forgive my ignorance as ive never messed aroudn with them , and only looked briefly at it once.
Reason i know its siezed as when it was on the ramps my mate had a look at it.
Is it somthing inside that actually siezes for the mechanism itself?
the joint its self rusts over stopping its movement mines slightly siezed but ive push mine right forward as i like the lightness it gives on tight braking corners
but think its atturly worked its way back as its not so snappy on the back,
could come round top off brands hatch hit the brakes and get the rear in to a little slide to dive the nose in
well im saying i pushed mine back and it gives more % to the rear, but has worked its way forward again,
just passing comment!!
i swapped mine at the weekend, both compensators came off without to much fuss but be very carefull when you refit it that you dont cross thread the pipes into the compesator. also make sure the compensator is held right in when bleeding the brakes after to ensure they bleed correctly then adjust to normal position.
its luck of the draw as to how difficult it is to swap and how good you are at putting things right incase you snap a pipe union etc.
i wasnt giving advice, merley saying
should i have writen a disclaimer
no worries, i have all the tools with regards to flaring pipes, and unions, ane benders etc..
Join retro Renault
http://www.retro-renault.com/forums/...ias-valve.html
some good info there mate, which has helped my understanding of it much appreciated
bit of an update.. the compensator came free
