Results 1 to 5 of 5
    Non-member paul-11turbo's Avatar
    merseyside
    11 turbo ph2 rear shocks
    Anyone know if there are any other renault models that use the same rear shocks as the ph2 11 turbo?
    Non-member Schakal's Avatar
    Barry
    Re: 11 turbo ph2 rear shocks
    Quote Originally Posted by paul-11turbo View Post
    i am pretty sure 1.7 gtx models will have the same shocks as they use the same axle.
    i got a pair here ,i can check part numbers if you can tell me yours .
    you can use shocks from renault 19/megane as well but you will have to swap
    the bottom mounting bushes as they are a different internal diameter .
    Non-member Paul R's Avatar
    have look on the bay m8 i bought a brand new pair of gas shocks for my phze 1 about 3 moonths ago and there awsome they have helped the handling no end
    and i think i only payed about £30 + P&P
    merseyside
    I bought a pair of new shocks and it has made no difference at all.
    Tha car is still sitting lower than it used to be
    I give up with these sheds i really do
    Barry
    sitting lower would not have much to do with the shocks.
    you may have a problem with the axle etc
