Results 1 to 5 of 5
    Non-member Schakal's Avatar
    Barry
    R9/11 Steering racks
    anyone know how many different types of racks were fitted to r9/11 s ?
    lookin at buypartsby.com there are 4 different types of racks including
    2 p/s ones ? i know mine is the manual ,splined pinion one but last one i bought
    that fits the criteria did not line up with the mounting points on the subframe
    Non-member paul-11turbo's Avatar
    merseyside
    Re: R9/11 Steering racks
    I had same prob with mine.
    Euro car parts had 2 types in stock with splined and square pinions and none was the correct type for my car.
    They both had the mounting brackets welded onto the rack like number 1 in the pic.
    My brackets are like C shaped and bolt the rack to the car like number 2 in pic.
    I ended up buying a 2nd hand one off a fellow member in the end.
    Barry
    looking at old pics , mine is same type pinion as number 2 but i think that
    end piece is an adaptor going over the splined bit ,which can be swapped over
    to a new rack ??
    the mounting looks same as number 1 though
    so what type pinion does the 11 turbo have mate ??
    merseyside
    Yes that universal joint thing comes off the pinion.
    mine has a round splined pinion.
    Hereford
    That sounds the same as my one. I had a real problem sourcing one for mine as I kept getting the thicker GTL/ GTS types when I ordered a turbo one! In the end I got a recon one, which took ages to get as they only had one in stock. I'm now selling my rack if you're interested.
