Page 1 of 4 1234 LastLast
Results 1 to 50 of 169
    Apr 2009
    sevenoaks
    piece of wotsit
    ivw so had enoth of this r5, dump valve wont close, engine mount busted last week, and now the rads popped even tho the temps were cool.....
    then were the wan..ers have ripped the dash apart cos the loom melted nothing has fitted back together, and the whole glove box has broken away from the dash.
    im realy getting fed up realy
    the thing thats realy winding me up is the sticking dump valve, ive lubricated it and it all moves freely, but no.. show it some boost and it sticks and wont clost till 5-6k in first and maybe 4k in 2nd so i get no boost,
    so it got a lil over rev coz its pissing me off
    and also whats getting me down is the bonnet and wing are in primer and no one seems to have them, i realy feel like its turning in to a dog and im going to end up scrapping it coz its ****
    any one wanna buy it.....
    Re: piece of $hit
    Shove a broom handle where the dump valve should go, then no more boost leak. just remember to block off the vacuum pipe going to it. Engine mount is not much trouble. remove bolts holding mount then just jack up the engine lifting it far enough from the engine mount so you can remove and replace then swap over. Should take too long to do. What do you mean the rad has popped? sprung a leak? is a copper core one?
    Apr 2009
    sevenoaks
    Re: piece of $hit
    i would block it but i hate the reverb sound, not sure why just doesnt sound right
    yer i know engine mount is easy but its like its fallen apart quicker than i can buy parts, i know its not but it seems like it
    na its leaking from the end cap were the top hose comes in. plus its well past its service life the cores are buldging and the metal parts inbetween are falling out.
    i dunno if i should get it back up to standards bar the body work and sell it, move on to something that dosnt involve spraying or replacing panals
    any one??
    Non-member BriC's Avatar
    Dec 2005
    Re: piece of $hit
    Dump valve.. Easy, throw it in the bin
    Engine mount.. Couple of hours to change
    Radiator.. Few minutes to change
    Dash and wiring loom.. A day to fit another dash and loom if you are confident. If not, get someone local to help you!
    Panels in primer.. Book it into a bodyshop!
    Easy peasy.. £300 at most fixes it (depending on where you get your paint done)
    Apr 2009
    sevenoaks
    Re: piece of $hit
    as above with all of that bric,
    its not just the wing and bonnet, roof looks like theres been breakdancers on it, rear bumper paint is flaking, skirts are held on with screws as the clips are like paper thin
    and then the some of the panals refuse to come up after a polish
    Quote Originally Posted by BriC View Post
    i had to refit the entire loom including o/s chassis loom
    Re: piece of $hit
    Find a local spraying, I paid about £80 just for a bonnet and wing to be sprayed. Find a dump valve off ebay which is working, but they always go wrong sometime or other, its just easier not having them in the first place. You will find most 5s will need work when you pick them up cheap, you need to pay the money to get a running one, and even then they are coming on 20 years old and things will go wrong and need replacing, but thats like any car this sort of age.
    Dec 2005
    Re: piece of $hit
    How much do you want for it?
    Edit: Balls.. just noticed how far away you live. Is it taxed and MOT'd?
    Non-member Tiny Tim's Avatar
    Oct 1999
    Bournemouth
    Re: piece of $hit
    I've got a dump valve for sale
    burton on trent
    Re: piece of $hit
    Dont worry so much.. My r5 is a dog, the engine has low oil pressure and leaks lots of oil. The bodywork sux, the rear 1/4s are rotton, the arches are bonded on , the paint is matt, the bonnet is black, the door is bent, the brakes dont work and rattle, the car handles toss.... but ill keep missioning on, and hopefully get it sorted bit by bit just take a deep breath and using folks help on here get the jobs done.
    Apr 2009
    sevenoaks
    Re: piece of $hit
    the dump valve works its sticking, i know this cos with the car running and vac hose off(dv closed) i put the vac hose on and took a sec to open and made a twang noise were it snapped open
    wouldnt i find a bonnet and wing for less then £80?
    i dont wanna dump the dump valve
    i dont like the chatter plus it makes it feel like it lurces forward after the throttle is depressed.
    i dunno whats it worth? if probs fixed
    Dec 2005
    Re: piece of $hit
    Quote Originally Posted by R5GTTRaider View Post
    Well if it's sticking, it's not working..
    Yeh, I'm sure you could find a bonnet and wing for less than £80
    I was asking about buying it as it is..
    Dec 2005
    Re: piece of $hit
    Wow.. sounds lovely
    Re: piece of $hit
    Erm, think you answered that question, you can get them for free if you can find them, but obviously your not having much luck there.
    Apr 2009
    sevenoaks
    Re: piece of $hit
    well it worked but was sticking alittle, opened t up and it had so much **** in there, whas best to use to kubricate it, or best left dry?
    Apr 2009
    sevenoaks
    Re: piece of $hit
    plus its got this ****ed up problem, every day itll start fine then itll start to turn over but then stop like its a dead battary, but if you flick the key a few times it turns over,
    cleaned the earth straps and the battary is ok plus alternater gives of good voltage im realy confussed
    Dec 2004
    Aylesbury
    Re: piece of $hit
    Sounds like you got a dodgy starter there mate, there common for the solenoids to stick.
    burton on trent
    Re: piece of $hit
    Wow.. sounds lovely
    Indeed , it certainly isnt a rot free perfect example like yours.
    and i forgot to mention my tailgate is also bent.
    Dec 2005
    Re: piece of $hit
    Hehe, although mine isn't rot free
    burton on trent
    Re: piece of $hit
    Shame considering its been fully sprayed.
    Apr 2009
    sevenoaks
    Re: piece of $hit
    at least mine hasnt got tin worm
    this is what is wrong/needs
    rad end cap by the top hose is leaking.
    rear engine mount shot
    front n/s mount on its way out
    need a top hose
    bonnet and wing need spraying or replacing
    rest of body work is scrathed or flat
    skirts need clips plus damaged
    need rear exhaust mounts
    glove box, but not the lid the hole compartment, infact the hole dash as it got ripped out, and screws were ignored..
    need drivers seat frame as the bar at the front has snapped one side
    rear bumper the paint is flaking
    upper o/s light trim has a dent?
    also boot trim looks like someone robbed the gtt badge and scratched the **** out the plastic
    front window needs replacing
    and now need a middle mirror hanger
    Dec 2005
    Re: piece of $hit
    Non-member DaveMayGTT's Avatar
    Fareham
    Re: piece of $hit
    Just cos its been resprayed only means the exterior is probably rot free, u should know these cars like to hide what is going wrong until 1 day you find it and its already hideously bad and to late to rescue
    Never give up though, just take your time.
    Apr 2009
    sevenoaks
    Re: piece of $hit
    so dump valves, should they be lubricated or left dry, its a metal piston with two o rings, then theres a second piston on a smaller spring that located in a hole on the first piston, any ideas
    Non-member Kenobi's Avatar
    Jul 2006
    Leicestershire
    Re: piece of $hit
    At least not whilst your in it.
    Dec 2005
    Re: piece of $hit
    Quote Originally Posted by Kenobi View Post
    Jul 2006
    Leicestershire
    Re: piece of $hit
    Dont cry the doctors can sort that kind of rot out mate.
    Oct 2004
    Somerset
    Re: piece of $hit
    ..hang in there buddy ,i have a dump valve and a bonnet you can have to the cause , im sure lookin @ the list youve put on her too , most things are quite minor and should be easy to fix..each year i have to write a list and i work through them all one by one, till it starts again.., dont give in...and i have 5 of the buggers..
    Apr 2009
    sevenoaks
    Re: piece of $hit
    raider bonnet?
    id swap you mine, its good condition with a clio type vent,well i dont mind mate suppose you want me to pay for postage
    Oct 2004
    Somerset
    Re: piece of $hit
    raider bonnet?
    Not raider in colour, i could write it on it?, if it makes you feel better.., pop along to pod , ill bring it and the valve...
    burton on trent
    Re: piece of $hit
    Quote Originally Posted by DaveMayGTT View Post
    Of course , i can respect that with straight up and over resprays and the likes, but looking through brics thread it appeared to be a pretty comprehensive project, almost restoration spec ( to a non standard level) and i imagine that any rot would of been tackled, other than maybe bits within chassis rails that cant be seen etc adn dave sbs's jobs seem to be pretty damn good/thorough. Anyway my apologies if that is not the case, maybe i presume to much.
    Just to add that seems a damn good offer from jesus.. a scrapyard local to me wanted £30 for a dented/damaged standard bonnet... i left it!
    Fareham
    Re: piece of $hit
    Yeh, brics does look like an amazing job/restoration. Jesus to the rescue eh, top man
    Non-member RICHIE's Avatar
    Jan 2004
    BEDFORD
    Re: piece of $hit
    is it a piston style dump valve or diaphram. piston style are very prone to playing up due to the crud that collects on them. i would clean it all up and use graphite to keep it operating freely
    Non-member JRP's Avatar
    Nov 2001
    Hogwarts
    Re: piece of $hit
    Use cooker tap grease to make it work freely, do wear gloves... thats shizzles messy
    Member clee's Avatar
    Derbyshire
    Re: piece of $hit
    What is cooker tap grease ......Chef Ramsey would have a hairy fit
    Re: piece of $hit
    Brilliant, you're so concerned about your car not working properly you won't even consider getting rid of a subbornly faulty d/v to improve the situation because of the way the car sounds without one.
    The piston style d/v has known to cock engines up completely when they stick open. Keep at it lad, you'll soon be shifting the car on, with a knackered engine on top of all the other problems
    Apr 2002
    Re: piece of $hit
    What i'm struggling to understand is, how can a 20 year old car have problems, and need money spending on it? I mean, it should be 110% perfect, especially a "hooligan car", like a 5 gt turbo, that's probably not had the easiest of lives
    Non-member Maka's Avatar
    Mansfield
    Re: piece of $hit
    hooligan woohooo
    made me chuckle
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    Re: piece of $hit
    should have bought the 'one lady' owner example an it would all
    be fine.
    Nov 2001
    Hogwarts
    Re: piece of $hit
    Quote Originally Posted by clee View Post
    Basicly graphite or what ever, british gas issue it, for when i get the gay task of re greasing old ladys cookers normaly the cookers in questions have not been cleaned since the 80's
    THE BAT CAVE
    Re: piece of $hit
    'old ladys cookers' is that what you call them??
  41. #41
    Oct 1999
    Bournemouth
    Re: piece of $hit
    "Alright love, i've come to grease your pipes"
    "Ooo young man"
  42. #42
    Non-member TrixNFlix's Avatar
    Preston
    Re: piece of $hit
    "Ooo young man"
    right were gonna need extra grease, you free again tomorrow love
    shame on you JRP
  43. #43
    Oct 2004
    Somerset
    Re: piece of $hit
    shame on you JRP
    ..jerpa sits rubbing knees..
  44. #44
    Apr 2009
    sevenoaks
    Re: piece of $hit
    haha "o young man!" love it...
    right dunno whats with the neg comments,
    still ill ignore it and move on, the dump valve works apsolutly fine now ive cleaned all the crap out.
    and billy i do know what 20 yr old cars are like i but older cars coz i like them always have and always will buy the 80's cars, i like them
    im just saying its all happening at once and its getting me down,
    not saying i wont fix it, just a bitch when things happen with in a week of each other
  45. #45
    Non-member rhys0_0's Avatar
    Swansea
    Re: piece of $hit
    be fine.
    The state my'n is in i dont think she has ever seen a lady
  46. #46
    birmingham
    Re: piece of $hit
    tbh mate the car sounds abit abit worst for wear.what was the car like when you 1st brought the car????then you can as yourself were did it all go rong/was it when u see the car and thought yep im having it and and drove of in the night or have the problems built up due to you not sorting out the problems yourself
    i find with the r5 you have to kinda look after and and be abit ott to make sure it will always run 100% and fingers crossed all is good.even with the price i paid for my car i still have about a few £££s of recipets so far its paid off and i love it
    all this talk of oh its a (r5 turbz) and the lark and is un reliable is a load of b****ks .its down to the owner imo.and yep im one of them who lets the car warm up!!!good 5mins.
    good luck
  47. #47
    Re: piece of $hit
    What did you do differently to the first time you cleaned it out then?
    You're not only ignoring the 'negative' comments but you're ignoring the sound advice as well. That dump valve design is known to be problematic on the GTT. You know why? Well, one of the reasons is because they gunk up quickly after having been cleaned out...
  48. #48
    Apr 2009
    sevenoaks
    Re: piece of $hit
    im not ignoring sound advice, i dont want to hear compresser surge all the time, and i want a dump valve, the first time i used atf oil, but it didnt work from the word go. today its been fine too, so hopefully its fine, and the dv is like 3 months old,,
    to other qestions ive had the car just over a month, and becasue the belt came off it popped the top hose and the rad at the same time, the enigne mount i did the other week, it was wet and i had it in reverse and my foot sliped off the clutch so it had torn the rubber away from the mount
    the car isnt realy worse for wear, rad and top hise and thats the underbonnet sorted, then its body work, i know ive changed my tune but yesterday i was fuked off.
    the car sits as it is the day i brought it apart from the rad and top hose
    oh and the fact it wasnt running as i had to replace the dash loom and o/s headlight loom and fog/horn loom
  49. #49
    Nov 2001
    Hogwarts
    Re: piece of $hit
    Quote Originally Posted by jesus in the seat of a 5 View Post
    I knew that would get you lot going hahahahahahahah whoooop whooooop better than ky
  50. #50
    Nov 2001
    Hogwarts
    Re: piece of $hit
    So the d/v is three months old... that just shows the problematic nature of them, eliminate surge, or as i call it the Horse death nay in slow mo, pop the standard air box set up back on.
    DUMP VALVES ARE GAY YOU SOUND LIKE A BUS
