Results 1 to 18 of 18
    Non-member bernard's Avatar
    Devon
    ronal turbos
    Im thinking about getting a set of these for the 5, but im pretty sure the center bore is going to be 57.1mm and renault are 60.1mm just wondering what people done about the size differnce can most machine shops sort this? Or can you buy adaptors/spacers?
    burton on trent
    Re: ronal turbos
    hmm wont spigot rings sort this, the little plastic/alloy rings that clip onto the centre of the wheels to bring the center bore down.
    Devon
    Re: ronal turbos
    yeah that would be right if the size were around the other way, basically the hole in the wheels is to small.
    burton on trent
    Re: ronal turbos
    ah crap , yea i see. Well im guessin maybe a specific spacer is used to pull then out slight whilst also altering that bore size. If it were me id certainly get a spcaer machined rather than the alloy itself.
    Devon
    Re: ronal turbos
    yeah Ive just been looking at some Hubcentric wheel spacers that have a 57.1 bore then I surpose you could have the spacers machined on a lathe easy enough, only problem is the wheels im looking at are et28 and the spacers are around the 20mm size.
    burton on trent
    Re: ronal turbos
    hmm, id get on wheel whores (google it) great forum for allos , mostly dub boys , but its helpfull. Im just putting some borbets on my 205 at the moment.
    Non-member Schakal's Avatar
    Barry
    Re: ronal turbos
    you can get them bored to 60.1mm at a shop where they got a lathe .
    had it done plenty times ,all good
    Non-member r5 rich's Avatar
    Romford, Essex
    Re: ronal turbos
    i know a few people running them on a clio 1.8 16v with no problems
    Non-member Winston's Avatar
    Re: ronal turbos
    Ronals have spigot rings standard.. so just get some 60.1 rings
    Non-member Mr 5's Avatar
    newcastle upon tyne
    Re: ronal turbos
    yeh what he said ^^^^^
    or do what i did,you van buy hubcentric spacers that are 60.1 hub-side...57.1 wheel-side
    Ollerton
    Re: ronal turbos
    I've got Ronal R10 Turbo's on mine, I bought them new and didn't have to do any machining. Infact the bore on my wheel is bigger than my hub.
    Sittard, Netherlands
    Re: ronal turbos
    Quote Originally Posted by Saint AAI View Post
    I've always wanted those for my 5 as well... PICTURES PLEASE!
    Are they 7J wide with an ET of 28 or 37? Did you have to modify anything for them to fit?
    Non-member Kempy's Avatar
    Milton Keynes
    Re: ronal turbos
    Quote Originally Posted by jantheeven View Post
    pictures in this thread mate
    https://www.rtoc.org/boards/showthrea...ighlight=ronal
    Re: ronal turbos
    Niiiiice! My 5 is also red, so now I have a good image on how they would look on my car! But still: what's the ET? Any modifications required for fitting those wheels?
    Non-member rs250nut's Avatar
    Re: ronal turbos
    Nice looking wheels but prefer the schmidt th-lines they are based on
    Non-member BriC's Avatar
    Dec 2005
    Re: ronal turbos
    Yeh, but have you seen how much they cost!?
    Re: ronal turbos
    Quote Originally Posted by BriC View Post
    Yep have a look in my album at a set I fitted to a 306 gti-6 a massive 10 inch on the back and 8 and a half on the front I cant get the picture up.
    Ollerton
    Re: ronal turbos
    Heres mine ET is 37 and they went straight on no problems, is it possible they do them with different bore sizes? Tried to google them and found one site saying it was 64mm and another said 68mm. Doesn't say anything on the Ronal site, but I'm sure you could e-mail them and ask just to be safe.
