Results 1 to 38 of 38
    Non-member Shakes's Avatar
    Apr 2009
    bristol england
    turbo removal
    hi im going to have a go of unbolting my turbo in a bit, anything i should know??
    or is it a simple bolt off job?
    also while i get the space there im going to be replacing the tdc lead anything i should know??
    or is it anotha simple job thanx
    Re: turbo removal
    If its not been off before mate, lots of WD40 i think its a relatively easy job!
    Non-member Tiny Tim's Avatar
    Oct 1999
    Bournemouth
    Re: turbo removal
    Why exactly are you unbolting it, just to do the TDC sensor (not needed) or replacement turbo?
    Apr 2009
    bristol england
    Re: turbo removal
    the oil seal has gone on the turbo, so need to send it to adam l.
    and mayaswell replace the tdc while im at it as the others a bit bodged with masking tape and block connectors everywhere
    Apr 2009
    bristol england
    Re: turbo removal
    its been on since 2001m better get the good old WD40 out i guess
    Apr 2009
    bristol england
    Re: turbo removal
    WHOOPY the turbo is off
    but wtf is this a hose right at the bottom of the turbo was corraded and the slightist movment snappet it! could this be causing the smoke??
    Tipton
    Re: turbo removal
    might be worth running the car for 30seconds to get the manifold hot-ish, to aid nut removal. then spray wd40 over all nuts!!!
    Apr 2009
    bristol england
    Re: turbo removal
    see this hose on the pictur thats circlede, this was very corroded a barly touched it and it broke away, what is this hose for???
    would it cause blue smoke on idle?
    Non-member Sy5GTT's Avatar
    Mar 2006
    Deepest Wilts
    Re: turbo removal
    that'll be the oil return hose mate.
    Apr 2009
    bristol england
    Re: turbo removal
    could it cause the smoke m8?
    or is it the oil seal?
    Mar 2006
    Deepest Wilts
    Re: turbo removal
    Sounds like a seal to me.
    Apr 2009
    bristol england
    Re: turbo removal
    ok ill get it sent to adam
    Re: turbo removal
    Is that the oil return hose? Did the hose that came off go down the front of the box towards the sump?
    Oct 1999
    Bournemouth
    Re: turbo removal
    I canny see no pictures!
    if its corroded, i'd suspect it was the water jacket pipe (outlet) rather than oil return
    Apr 2009
    bristol england
    Re: turbo removal
    the hose is connected to the very bottom of the turbo and seems to go to the bottom of the sump
    Apr 2009
    bristol england
    Re: turbo removal
    ive added a pic of it on my profile
    Oct 1999
    Bournemouth
    Re: turbo removal
    Worst picture EVER!
    But yes, looks like the oil return.
    Re: turbo removal
    Could be the cause of smoking, if the smoke was coming from the engine bay and not the exhaust?
    Apr 2009
    bristol england
    Re: turbo removal
    posted a few pics of turbo on my profile now.
    https://www.rtoc.org/boards/member.php?u=1402 i was told when i bought the car it was a garrett t28, can anyone confirm this also as most of u probbaly know buy now it seems the oil seal is knackerd! IS it worth rebuilding??? or am i better of replacing it??THANX
    Apr 2009
    bristol england
    Re: turbo removal
    any advice then?????
    Non-member rs250nut's Avatar
    Re: turbo removal
    Speak to Adam L hes the man on here when it comes to turbos. Really depends on how much money you want to spend and if you are happy with the way the turbo works?
    Member D4WNO's Avatar
    Jul 2004
    London
    Re: turbo removal
    Yeah, give Adam a call tomorrow @ Turbo Developments on 02085 603927
    Non-member Adam L's Avatar
    Feb 2003
    SW London
    Re: turbo removal
    The seller lied about it being a T28 too...
    Apr 2009
    bristol england
    Re: turbo removal
    Has anyone had any work done by a company called Ivor searl in Cambridgeshire?
    http://www.ivorsearle.co.uk/public/i...t=0&sh=24&cp=7
    as unfortunatly for me adam is very busy atm and wont be able to look at my turbo for a couple of weeks. it is my only car and need on the road asap, also i want it at its best for santa pod, and is cutting fine as theres more work i need doing after the cars running again.
    ivor searl recon they can get the turbo back to me within 5 days. which sounds great, But are they any good???
    Jul 2003
    Re: turbo removal
    Quote Originally Posted by sh5tie View Post
    A-D-A-M L!!!!
    Not sure why you're not seeing this??
    He works for Turbo Developments & is a 5 GTT fan so who better to sort your turbo??
    That's my 5 pence worth BTW
    Jul 2004
    London
    Re: turbo removal
    He does but T.D are rushed off their feet at the moment and just don't have the time to do it before Pod. Could you get a donor turbo for now and send the damaged one off to Adam?
    Apr 2009
    bristol england
    Re: RTOC @ Santa Pod, 29th May 2009
    yes m8 ive spoke to adam l, and i would love for him to do the work on my turbo, but like i said he is very busy and he cant even get to look at it for 2 weeks
    i need the car running asap as i want it in time for santa pod, once the car is running it then needs to go to the garage to have some more work done to it
    it just wont be ready in time
    Non-member JRP's Avatar
    Nov 2001
    Hogwarts
    Re: turbo removal
    i have a donor t2 turbo its basicly new so you would be butcherd if you killed it,
    Apr 2009
    bristol england
    Re: turbo removal
    ahh im fo*ing everything up lol this turbo is driving me crazzy lol
    thanks for the offer jrp, very kind but i wouldnt like to chance it just incase anything does go wrong
    Jul 2004
    London
    Re: turbo removal
    Lol, what's going on with your posts? You posted a reply to this on the Pod thread, then said "oops, wrong thread" on the RIGHT thread ...have sorted it all out now
    Apr 2009
    bristol england
    Re: turbo removal
    haha no idea im rushing trying to get ready for work and still giggling about that carrot on a stick link from ebay, hahaha i cant stop giggling
    Re: turbo removal
    I might get slated for saying this but try a company called c.r turbos in new milton they offer a quick turn around and have built turbos on some of the quickest cars in the country
    http://www.crturbos.co.uk/
    01425 638426
    Or failing that
    http://www.turbodynamics.co.uk/
    Or failing that
    http://www.universal-turbos.com/
    Or failing that throw it in the bin
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    Re: turbo removal
    Im TOLD that universal turbos in Ringwood are supposed to be good
    Nov 2001
    Hogwarts
    Re: turbo removal
    If it gets you out the **** its here dude, i wont butcher you
    Loose Bolts Tuning stuTHC's Avatar
    Dec 2005
    Leeds
    Re: turbo removal
    It is worth replacing the 2 rubber sections of the oil return line if they are old and brittle on the outside. The rubber inside goes soft and closes up causing a restriction. This can cause oil to back up in the turbo and it to smoke. The rubber hoses are about £20 each from renault, a lot cheaper than a turbo rebuild
    Apr 2009
    bristol england
    Re: turbo removal
    getting some good help here
    thanks all i will ring around see how it goes.
    thanx again for the offer jrp, i may take you up on that as a last option but hopefully it wont come to that
    Apr 2009
    bristol england
    Re: turbo removal
    Quote Originally Posted by stuTHC View Post
    the oil return hose was very britlle while i was removing the turbo it snapped away before i could even get chance to touch the hose clip, however i was getting alot of blue smoke from the exhast and was told, the broken hose would cause smoke from the bay but not from the exhast
    Non-member Nayls's Avatar
    Weymouth
    Re: turbo removal
    01425 638426
    Or failing that
    Or failing that
    i strongly advise crturbos from that list!!
