Mart
Chris, the afr's may have been ok (albeit mega rich) back at the RR day, but how d'you know that's been the case since? Doesn't take much to go wrong with the fuelling supply and/or carb to cause lean fuelling conditions.
Even if the afr's were fine though, with no pressure reference at the aei (vacuum capsule), it'll be constantly running a v.advanced ignition map, with, and to mention again, no retard of the map when positive pressure/boost is seen. That, coupled with 17psi boost, and you're defo into detonation territory.
Yep, a boost leak from a dump valve pipe (or any other pipe on the aei line) would be enough to limit, or remove altogether, the amount of vacuum & boosted air getting to the vacuum capsule - It's possible the vacuum capsule could've constantly just been reading atmospheric pressure.
A full stripdown might be ok, but either way you cut it, it's exactly that - A full stripdown, followed by a thorough clean of everything which is in contact with oil. Likewise, if the turbo has been spitting out metal, the intercooler will require a good internal clean up too.
