Results 1 to 6 of 6
    Non-member TURBO'D CLIO's Avatar
    Apr 2009
    devon
    Battery in boot conversion help please !!
    I'm putting my battery in the boot of my car and was wondering if this cable is high enough amperage or will it melt when i start the car lol..
    http://cgi.ebay.co.uk/10M-REEL-RED-2...4.c0.m14.l1262
    Apr 2009
    devon
    Re: Battery in boot conversion help please !!
    Any one???, i wanted to order the cable tonight..
    Looks OK that, if it turns out that there's too much of a volt drop then you could double up with it. I think it said there was 10M on the drum ?
    Apr 2009
    devon
    Just wernt sure what the ampage of the volvo engine was when it's cranking? I was also going to run a seperate earth from the battery to the front bay so all the ecu's get a good earth etc...
    Non-member IANMM's Avatar
    Sedgley
    Quote Originally Posted by TURBO'D CLIO View Post
    put a clamp meter over the live feed while you crank it over and that will tell you the load
    Sedgley
