Results 1 to 5 of 5
    Nov 2008
    kings lynn, norfolk
    power of standard turbo and stuff?!
    does anyone no how much bhp you can get out of a standard turbo? would i be right in saying with other mods, about 150bhp?! and also my fan is on a switch...how hard is it to connect it back to the tempature switch?
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Re: power of standard turbo and stuff?!
    Should be able to get an easy 150hp out of the standard T2 blower. It starts max'ing out around 170-180hp though.
    Non-member JRP's Avatar
    Nov 2001
    Hogwarts
    your fan is on a switch? hmmm should be connected so that it comes on still with out the switch, incase you forget.
    just trace the fan wires, and pop them back to the stat, then t- off from that with the switch/over ride wire.
    Nov 2008
    kings lynn, norfolk
    looks like they've just connected the switch straight to the fan, so im thinking there be a reason for it but im goona see wot happens anyway. cheers guys
    Nov 2001
    Hogwarts
    Quote Originally Posted by ains View Post
    change the stat/switch, plumb it in as per norm as it should be, then add the manual switch.
