Results 1 to 18 of 18
    Non-member Kenobi's Avatar
    Jul 2006
    Leicestershire
    YES a Dump valve question.
    hey all,
    Just a quicky, Is it possible for a re-circ dump valve to lose you boost pressure?
    Thanks
    Non-member Tiny Tim's Avatar
    Oct 1999
    Bournemouth
    Re: YES a Dump valve question.
    Not unless its leaking/has a stuck piston.
    Jul 2006
    Leicestershire
    It shouldnt be. On the gauge it seems 2psi less with it in place.
    How does a recirc one work. In words i can understand lol
    Non-member Shane P's Avatar
    Jan 2006
    Quote Originally Posted by Kenobi View Post
    The clue is in the name
    Oct 1999
    Bournemouth
    As opposed to what, running without?
    Rather than dumping the air to atmosphere, it returns the dumped charge air to the air inlet line between the air filter and the turbo compressor housing to aid spool-up/keep the turbine spinning.
    Jul 2006
    Leicestershire
    yeah thats what i though.
    the standard recirc doesnt lose 2psi. its made of plastic.
    Oct 1999
    Bournemouth
    The usual black plastic Bosch no doubt then. Stick the OE re-circ back on then?
    Non-member Spooky's Avatar
    Sep 2001
    SW PMT HQ
    I've forgotten how awesome dump valves are, my car is wearing one now and I've been chuffing all morning
    Oct 2003
    so gay so so gay, let down spooky
    Aug 2004
    I remember taking Ricardo out in my grey 5 after he fixed at got it running...
    when the dump valve went you should have seen his face duck down in shame... a quality moment i shall not forget.
    Oct 2004
    Somerset
    Quote Originally Posted by Penfold View Post
    you still got that one on the cup.......
    Non-member sphinX's Avatar
    Feb 2005
    Telford
    theyre fun when u first put them on, driving around going woooshhh all day haha
    Aug 2004
    Quote Originally Posted by jesus in the seat of a 5 View Post
    I most certainly have, although i have an uncut boost hose to go on after soon enough.
    Non-member jure's Avatar
    Split (Croatia)
    It depends what rate spring you have. If you have black Bosch one or Forge ally replica they should cope bit over 20psi if in good working order.
    Jul 2006
    Leicestershire
    Quote Originally Posted by jure View Post
    Hmm, this is adjustable?
    What would be the point of an adjustable recirc D/V.
    On mine all i know is that if it isnt around 0.8 0.9 bar my car goes into limp mode.
    Split (Croatia)
    Same one as "normal" adjustable dump valve. You adjust piston tension on which pressure you want valve to start dump the air.
    Non-member markey b's Avatar
    Bury St Edmunds
    on the forge i think i put a green spring in and stretched it a bit, was nice because it only 'dumped' with proper boost not pissy half throttle because it got annoying going off every 30seconds
    Split (Croatia)
    Same thing here but mine was doing that with green spring inside. Bought it as "group A" BBPT DV. I took it off anyways
