Results 1 to 14 of 14
    Clio 172 3pin connector on throttle body
    Does anyone know where I can buy it with the pins or what to ask for at Renault as they're usually funny if I'm either not precise or have the chassis number
    Any help appreciated
    Oxfordshire
    Re: Clio 172 3pin connector on throttle body
    what does it look like? any chance that it's a 3 pin version of an injector connector?
    It looks more like the map sensor connector but that's slighly bigger
    here's a pic
    Sorry to those who's screen was just filled with a giant image
    Oxfordshire
    does it look like this?
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    I spotted some connectors called "Superseal" in a catalogue a few weeks back that I thought looked like the renault ones. No idea if they are actually the same, I suspect they might be renault only. Most OE connectors are
    Oxfordshire
    I bought some of these from Vehicle Wiring Products, they were quite big
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Even the 3 pin andy ? They said 1.5mm pins, but thats no real gauge on their total size I suppose! As I say, only saw them in a catalogue
    Oxfordshire
    do you have a highlighter to hand?
    that looks a little bit wider.. I think it's a trip to the scrapyard or renault and hope for the best.. thanks for your help though
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    i'll have a look in my garage when I get a sec, I didn't use the 172 TPS so may have the old one + Plug to hand somewhere!
    I'd appreciate that!! thanks mate
    Quote Originally Posted by Andrew Warren View Post
    I've found out that it's a CS14 magnetti marelli 3 way plug that I need but I've not managed to source one
    Member clee's Avatar
    Derbyshire
    I've got few of that sort on old GTA looms .I have a few of varying colours .There are different patterns of slot on the plastic surrounding the pins so they will only fit their mating sockets .I'm near Notts , if you get stuck you can always pop in and rob the bin .
    Quote Originally Posted by clee View Post
    I appreciate that! - thanks I'll give you a shout if I don't sort it this week
    cheers!!
