Results 1 to 14 of 14
    Non-member raj's Avatar
    Feb 2001
    Rohtang pass
    Car Help Pls.!
    this is regarding the car i use for taxi hire, its a 02 toyota avensis.
    what areas should i be looking at to source the problems its having?
    problem is that it will randomly start hunting! the revs will rise and fall between 500 and 1000 rpm.
    sometimes its fine but more than often it does the above.
    Ivybridge
    Re: Car Help Pls.!
    It will probably be a sensor, try coolant temp sensor...
    Feb 2001
    Rohtang pass
    Re: Car Help Pls.!
    how would a coolant temp sensor effect the idle and cause hunting
    Apr 2009
    sevenoaks
    Re: Car Help Pls.!
    by the car not knowing the temprature of the engine to ajust the fueling correctly??
    Feb 2001
    Rohtang pass
    Re: Car Help Pls.!
    Quote Originally Posted by R5GTTRaider View Post
    ok thanks
    any other areas i can check?
    Apr 2009
    sevenoaks
    Re: Car Help Pls.!
    vacum leaks
    always a major player in hunting, or tps
    check all vacum hoes and any spilts AFTER the afm in the inlet pipe
    after that then itll be a dignosic check, think there moble guys that charge ?£40 for the first hour and 25 after , but with what can be said to be a simple problem could take less then a hour, but if theres no error codes your be lost even more,
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: Car Help Pls.!
    check for air leaks, cracked pipes, that kind of thing.
    have you had diagnostics on it ? is it throwing up any fault codes ?
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: Car Help Pls.!
    oops, I was a bit slow that time
    Feb 2001
    Rohtang pass
    Re: Car Help Pls.!
    vacum leaks
    thanks for that bud will give it a good look over.
    Feb 2001
    Rohtang pass
    Re: Car Help Pls.!
    not done a diagnostics check yet, was hoping to try sourcing the prob before spending money on it. also im assuming a buggered lambda sensor can cause this prob too?
    Tipton
    Re: Car Help Pls.!
    you can use any OBD tool to have a look at it as its after 2000 and a petrol model. this should then tell you which area to start looking in.
    Non-member Frix's Avatar
    Re: Car Help Pls.!
    this is the first thing i would check Raj!! lambda sensor is more than likely your problem!!
    Non-member Tiny Tim's Avatar
    Oct 1999
    Bournemouth
    Re: Car Help Pls.!
    I'd check the idle control valve as well.
    Non-member TURBO'D CLIO's Avatar
    Apr 2009
    devon
    Re: Car Help Pls.!
    Agree, give it a clean with carb cleaner or brake cleaner while your at it to...
