With my car withnin a few days of being back on the road and having an external wastegate I've started looking into how to set it up properply but I've hit a snag.
Normally when you have an external wastegate controlled by an electronic valve theres no internal wastegate in the turbo to worry about but with a VNT you have to keep the actuator or it won't make boost, now if I was just gunna run the boost pressure of the wastegate it'd just be 1 vacuum line split between the 2, with a bleed valve you'd fit it before the split but with an electronic valve you have 2 vacuum lines to the external wastegate.
How do I plumb in the wastegate, valve and VNT actuator?
Has anyone fitted an external wastegate to a VNT powered R5?
And before you say it, yes I have used the search function and Google and come up with nothing
