Results 1 to 29 of 29
    Oxfordshire
    how do I get these fuel pipes off?
    I'm in the process of swapping the fuel pump from the clio into the Twingo. No problem getting the pipes of the clio, but the Twingo has me stumped.
    help
    Re: how do I get these fuel pipes off?
    do you not just press the green or red tab IN (toward the black pipes) whiles pulling them off the sender ? like you would with nylon quick connects.
    Oxfordshire
    nothing seems to move, I've pulled, levered, twisted and hammered so far
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    try pushing the black pipe in towards the green / red arrow (i.e. the opposite way to pulling it off) then slide the sleeve back the other way to relase the connector.
    Oxfordshire
    I'm pulling and prodding but it all seems tight. Still, the manual shows how to do it
    Oxfordshire
    bugger it, I can't get it apart, and it's starting to look a bit second hand now
    maybe the collar is stuck fast, does plenty of wd40 not free it up ?
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    its all about the MOT1265!!
    Non-member olidaviesuk's Avatar
    Nov 2008
    Bromley
    I think there is a special tool for those connectors, they look suspiciously like those on a fiat coupe I had the 'pleasure' ahem (not) of rebuilding the engine on - the tool looks similar to circlip pliers..
    help
    Regional Rep Chris Hebden's Avatar
    Andy, on that green connector nearest the camera, there should be a tiny little tang sticking through the black connector, i think on each side of the plug, that you have to push in and pull the connector of at once. I used to use a little watch screw driver or something of that nature.
    Salford (manchester)
    On the green one (if im right as it looks similier to some porsches) normaly there is a half moon ring that sits in that gap showing, u remove this and push the inner sleave towards the tank till the couple mm gap is closed and it will then pull the whole thing back... Im so ****e at explaining... red one i aint a clue from the pic...
    Oxfordshire
    Quote Originally Posted by Rob@Backyardracing View Post
    there was a 1/2 moon thing that I removed. Pushing and pulling is doing my head in. Fortunately I'm taking my mind off it by making engine mounts. The down side is I looked at the tank to take my mind off the bloody engine mounts
    Member clee's Avatar
    Derbyshire
    Maybe totally wrong but they look like compression fittings .You need to close up the gap on the outer retainer and then pull the pipe out .....Maybe ....Like Rob says but just pull the pipe back .
    Dublin/Ireland
    i think u sqeeze them like u would a childproof cap(deform in 2 places)they look the same as a clio fuel filter!??
    Oxfordshire
    Quote Originally Posted by michael tierney View Post
    it's not that, I've pulled one of them off the clio, so would recognise it.
    Something else I've noticed is how many different types of electrical connector Renault use, each one with a different release technique
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    help
    maybe you remove them camotzi style or very similar to the vw stuff,i only know that
    because i removed them to drain a mates tank before...petrol in a diesel...
    Non-member TURBO'D CLIO's Avatar
    Apr 2009
    devon
    Andrew
    Where the black pipe goes in there is a black round bit at the bottom of the connector, push that black bit towards the coloured end whilst trying to pull the pipe off at the same time..
    Do these all the time at work, they really are on there tight kist keep trying, pust that black bit up as hard as you can then pull the pipe off...
    Good luck..
    Just noticed ones black ones red, same idea thou.. push the round bits up closest to the pipe end, push them towards the sender unit and pull off at same time...
    Oxfordshire
    I've had a bit more luck, I found a union the same as the red one on the engine, with the bit in my hand I was able to work it out. The one on the engine was clear. Basically the low pressure ones (like the red return) are collets, you push the body towards the tank, then with a small pointy thing you push back the inner ring, then slide the whole lot back. Came apart very easily once I'd worked out how it worked. Unfortunately I could have just cut that one off, it's the green one I need to save.
    Non-member mr bean aka pete's Avatar
    Jun 2006
    oxfordshire
    andy you need a special pair of pliers to remove thos clips as i work for renault in oxfordshire and not far from you i can bring them along if you want ??? if your really stuck
    Oxfordshire
    Quote Originally Posted by mr bean aka pete View Post
    thanks, I've just done it... nothing seems to move, but I pushed the pipe with pliers, and levered the body back with a small spanner - then a thicker spanner etc. so yeah, it works a bit like disconnecting an airline, but with more force, and less movement. I can imagine that the right pliers and a day at the Renault training center would make the job easy
    Jun 2006
    oxfordshire
    glad you got the connectors apart, but having the right tools makes all the differance
    Oxfordshire
    Yeah, I'll have to get an MOT1265 for my toolbox
    Jun 2006
    oxfordshire
    can buy patten part pliers they come in a set of 3 for different types of connectors
    Oxfordshire
    you've convinced me, clicky, clicky
    Apr 2009
    devon
    Yeah i bought them, snap on ones i got are shi*, my boss bought 3 cheapies off ebay and they work a treat...
    http://cgi.ebay.co.uk/Fuel-Line-Disc...1%7C240%3A1318
    Also - Did that 172 fuel pump fit direct into your original slot or was there some modding involved..
    bracknell
    i feel a youtube momment comming on
    http://www.youtube.com/watch?v=_59n86U3Dvs
    Oxfordshire
    Quote Originally Posted by TURBO'D CLIO View Post
    I was hoping to drop the whole unit into the tank, but the Twingo has a load of walls around the pump, so I'd need to cut them out. The latest plan is to disassemble both units and try and fit the 172 pump and regulator into the Twingo housing. I will unfortunately lose the 172 collector when I do that. At the moment I don't know what will fit where.
    bracknell
    Andrew i have to say when those type of conector thgy wotzits were used on fuel fillters .(early slagooners) . we had to cut the pipe and fit differnt connector
    your pdf file gave me the nightmare back again
    Apr 2009
    devon
    Quote Originally Posted by THE MASTER View Post
    Twist n shout..
