Results 1 to 20 of 20
    Zafira GSI Help
    Last night on my way home from helping a fellow member remove and strip his engine from his GTT.
    I ran in to my own problems on the M25 all of a sudden my Z20LET engined Zafira warning light came on the car then sounded like it was running on 3 cylinders. I am not to good with these modern engines but I think it could be a coil stick or pack failure, it wasn't very light by the time I got home so no chance to have a look will be hopefully be fixing over the weekend.
    The temp gauge was fine, and no smoke or anything from the engine or exhaust, no leaks when checked, I will check sparkies any other suggestions?
    Re: Zafira GSI Help
    Anyone??
    I will add the following, No loss of coolant, idle seems ok if a little lumpy (to be expected if running on 3 though) exhaust note has changed (Again to be expected if running on 3) sounds more beastley.
    Will check the oil level over the weekend as well.
    Oxfordshire
    Re: Zafira GSI Help
    are the coils the coil on plug type? they're pretty common to fail. It's about time you got an OBD reader - you know, the one you need for the 5
    Oxfordshire
    Re: Zafira GSI Help
    I've borrowed one of these from a guy at work to see how I get on.
    http://cgi.ebay.co.uk/OBD-II-EOBD-US...3A1|240%3A1318
    and downloaded the free version of this
    http://www.palmerperformance.com/pro...lelm/index.php
    and this
    http://www.scantool.net/scantool/dow...stic-software/
    obviously I haven't been able to plug it into anything yet.....
    Re: Zafira GSI Help
    The coils are the coil stick type directly attached to the sparkies but they are connected to a big block that is attached to all 4 and they do not sperate from the block at all So if one goes the whole setup needs to be replaced
    I have been looking into OBD readers and just not to sure which one to get but it would help diagnose some problems.
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: Zafira GSI Help
    Andy, would that exact reader that you have linked connect to my 182 to clear the fault lights? not bad for £7.00 if it works?
    Oxfordshire
    Re: Zafira GSI Help
    Quote Originally Posted by Ashy View Post
    I believe so Ashy, I'll know better once I've plugged onto mine
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: Zafira GSI Help
    nice one can you let us know how you get on?
    Re: Zafira GSI Help
    Ashy, I have just gone and ordered a hand held jobby as have no lappy. Once it arrives and I have finished you are welcome to use matey
    Now all I need to do is get an OBD-II port with a section of loom for the 172 lump hopefully one of the cliosport boys are breaking a car
    Oxfordshire
    Re: Zafira GSI Help
    if you can get hold of a connector and length of loom out of anything you'll be able to wire it in
    Committee member
    Rats Nest Tuning
    Ashy's Avatar
    Re: Zafira GSI Help
    Nice one fellah
    Non-member TURBO'D CLIO's Avatar
    Apr 2009
    devon
    Re: Zafira GSI Help
    Common fault on the 20 let lump im affraid mate..
    Coil pack is one whole long piece, powers all 4 plugs in one go.. Cost's £120 from main dealer..
    I would also like to add that where possible fit main dealer parts to vauxhall cars as the prices are very very good, a after market coil pack is around the £100 and a load of **** if you don't mind me saying, better to spend a extra £20 - £30 quid and get a proper one, and being 200 bhp standard you want a nice clean healthy spark...
    Hope this helps,
    rob
    Apr 2009
    devon
    Re: Zafira GSI Help
    Yup theres a 172 being broke on there, well 2 infact..
    Oxfordshire
    Re: Zafira GSI Help
    diagnostic socket is 225, I can talk you through it if you need
    Re: Zafira GSI Help
    Your going to have to looking at that diagram
    Oxfordshire
    Re: Zafira GSI Help
    lol, it's pretty simple, you only need to worry about the wires going to the connector
    Re: Zafira GSI Help
    Simple I can't even get my R5 to run
    Andy if you have no luck with that OBD you have borrowed you are also welcome to use this hand held thing I have ordered.
    Oxfordshire
    Re: Zafira GSI Help
    Tipton
    Re: Zafira GSI Help
    Ashy, the OBD reader will only turn off the engine light, not do any of the ABS or anything like that. its for emissions only....
    Re: Zafira GSI Help
    Well the problem seems to be fixed I purchased a new coil pack anyway from Vauxhall and done a basic service myself and the fault seems to have gone so I am assuming it was the coil pack.
    Still got OBD Reader on the way.
    Thanks for all your help and advice.
