Page 2 of 2 FirstFirst 12
Results 51 to 82 of 82
  1. #51
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    Re: Renault 5 gt turbo part numbers
    is it possible to delete all the questions on this thread for folk asking for part numbers?,just clutters it up,if its not listed with all the numbers folk have took time to post up,thats if you have bothered to look through them all,just sayin..
  2. #52
    Non-member adscan's Avatar
    Apr 2011
    anybody have the part numbers for the front suspension bushes? i need inner and outer anti roll bar bushes and 4 wishbone bushes.
    cheers
  3. #53
    77 00 779 923 - LHS
    77 00 779 924 - RHS
    Part numbers for side skirt rubber strips
  4. #54
    Non-member Hoolio's Avatar
    Wallingford
    Quote Originally Posted by adscan View Post
    cheers
    Did you sort these? I can check if not.
  5. #55
    Non-member gttjames's Avatar
    Cambridge
    oe renault
    oil filter - 7700727482
    fuel filter 7711130026
  6. #56
    Those caps which cover up the metal brackets of the rear seats
    77 00 763 002 - £1.02 each
    Boost hose rubber strap - same as brake reserve tank
    77 00 695 993 - £2.32
  7. #57
    South Wales
    Anyone got the part number for the euro rear light?
  8. #58
    Farnborough
    Does anyone have the part number for the fixings which hold the rear arches on. They seem to be like a stud with a self tapping/screw thread one end and a normal thread and nut the other if you get what I mean.
  9. #59
    Non-member WASTEGATE's Avatar
    Jan 2013
    Looking for part number of steel spare wheel phase1
  10. #60
    Cambridge
    sandwhich plate to block O rubber seal
    Part no is 7703061090
  11. #61
    Trader
    GT Turbo Spares co.uk
    South East Regional Rep
    phase i 16 v turbo's Avatar
    Jan 2001
    Morden
    Quote Originally Posted by WASTEGATE View Post
    keep in stock
  12. #62
    Cambridge
    sanwhich plate to block seal 770 306 1090
    side skirt clips 770 308 0051
    side skirt rivets 770 307 2197
    no. plate lamps 770 136 6035
    osr wheel arch fuel tank bracket that rots away 770 307 8180
  13. #63
    Non-member 123-gtt's Avatar
    Nov 2011
    Quote Originally Posted by MattChester View Post
    Anybody know the part number for the split pin thing for holding the driveshaft to the gearbox? Or anywhere other than renault I can get one Thanks
    I just went to halfords and they do a roll pin pack, with spot on sizes you need
  14. #64
    West Midlands Area Rep w35ty's Avatar
    Feb 2009
    Walsall
    Do renault still stock oil pumps?
  15. #65
    Quote Originally Posted by w35ty View Post
    A few years back they did but then you didn't get much change from £400, not sure if they only sell the non turbo version possible as remember hearing stories of people putting in new oil pumps and not getting enough oil pressure
  16. #66
    Farnborough
    Have a read of Ian's article on oil pumps before you shell out any money. It gives you all the info you need to make sure you get a genuine pump for a turbo model rather than one for a n/a 5 - https://www.rtoc.org/boards/showthread.php?t=4730
    Bigfoot is right, there were tales of people using non turbo oil pumps and messing up their engines.
  17. #67
    Feb 2009
    Walsall
    Il pass on the £400 sooner go conversion than spend that much on one, cgb reurb ones anygood? There £160 il have a read up onit too
  18. #68
    Nov 2008
    Croydon
    A few years ago there was a pricing discrepancy with oil pumps. Renault used to operate with multiple pricing systems and one system (local uk pricing) showed £400 but the French system had them at £150, my friendly stealer managed to get me a brand new one at the £150 price
    Not sure if its the same situation now though, only one way to find out I guess..
  19. #69
    Non-member Gtturbo's Avatar
    Mar 2013
    BB Code
  20. #70
    Non-member Jonny5's Avatar
    Sleaford
  21. #71
    Cambridge
    Quote Originally Posted by Gtturbo View Post
    BB Code
    how much they come in at? do they just pop out?
  22. #72
    Non-member casper's Avatar
    Jul 2012
    Does anyone have the part numbers for the plastic wheel arch inserts?
  23. #73
    Nov 2009
    Cambridge
    Here is a list of genuine coolant hose and air hoses I`ve manged to get from Renualt so far, please can someone list any numbers for coolant hoses that they`ve managed to get not on this list.
    6001021209
    6001006589
    6001021212
    6001007412
    6001007413
    6001008136
    6001006590
    6001008463
    7701203219
    Maybe of some help to someone
  24. #74
    Mar 2013
    Quote Originally Posted by gttjames View Post
    Came up on eBay one night, £10 posted
    Yep just pop out mate.
  25. #75
    Member Woznaldo's Avatar
    Canberra, Australia
    Ladies and Gents, has anyone got the part number for front wheel bearings? I've got a track day on Friday and while doing an oil change and pulling off the old front brakes, I noticed that the Front LH wheel Bearing is completely shot!
  26. #76
    I think it should be:
    77 01 205 778
  27. #77
    Canberra, Australia
    Quote Originally Posted by Bigfoot View Post
    77 01 205 778
    I think there are a few of which the one above is one. Possibly because they give a different part number when fitted to another car? Here' some more:
    7700841979, 7701205778, 7701462469, 7701465181
  28. #78
    That is quite possible the reason, my system is picking up the all the part numbers apart from the first one and x-ref them over to fit the Renault 5 gt turbo.
  29. #79
    Canberra, Australia
    Cheers Dale, I might ditch the first number when I hit the parts shops tomorrow. I'll try Renault first and if the cost isn't ridiculous, I'll just get it there.
  30. #80
    Non-member Tuck's Avatar
    Dec 2014
    Dose any 1 know the part number for a phase 1 suspension leg thank you
  31. #81
    Non-member Kieron's Avatar
    Mar 2015
    Hey Just wondering if anyone has the windscreen scuttle panel part number? (as mine is starting to rust) and is it even possible to get one now? i phoned Renault and it has obviously been discontinued, does anyone have one they would like to sell? or does anyone know any after market manufacturers that makes them?
    Thanks
  32. #82
    Apr 2014
    Lockset (doors x 2, hatch x 1 and fuel cap)
    77 00 795 831.
    (Please note that the keys supplied are the newer style with an ignition lock style key blade, not the diamond keys)
