Page 4 of 19 FirstFirst 1234567891011121314 ... LastLast
Results 151 to 200 of 944
  1. #151
    Re: Turbo Toaster
    Quote Originally Posted by d110rkjste View Post
    what turbo do you have? an how did u get all the cozzy parts on it?
    Its a VNT turbo courtesy of Adam L at turbo developments, top man he is.
    The cozzy fuel rail and pump were lying in a box of bits belonging to the guy who made my inlet manifold, he had to shorten the fuel to suit and adjust the factory pump bracket to fit the cozzy job, so it was easy........... for me anyway, he had no end of trouble with the rail, it kept springing leaks but its been perfect since
  2. #152
    prescot, liverpool
    Re: Turbo Toaster
    is right, i had a volvo 480 turbo engine in mine fitted it with my m8, but changed back to a r5 engine as it needed much more work. was fast though
  3. #153
    Re: Turbo Toaster
    I've heard that, but it should so much easyer to adjust the fueling cus its efi from the factory, what you done to ya C1J lump then?
  4. #154
    Non-member Ben's Avatar
    Ruislip
    Re: Turbo Toaster
    had a vnt turbo from turbo developments on my car for a few track days, until it went pop. need to get it totally re built including turbine shaft and compressor wheel. as stated before the slender shaft isnt exactly robust and dont know if i should bother with it again. like the idea of a seperate waste gate though.
  5. #155
    prescot, liverpool
    Re: Turbo Toaster
    i bought the engine fom a lad it had new pistons an tht, wacked a group a head gasket on, bigger turbo, messed round with the carb an tht, got hold of a gt tuning intercooler the cybercool 1, the lad who i bought the engine off also said bb tuning messed ound with the head, it runs sweet best engine ive had, running it on 20 psi like goes like mad even with 17s on
  6. #156
    Re: Turbo Toaster
    Have you ever had it dyno'd to see what power its making?
  7. #157
    prescot, liverpool
    Re: Turbo Toaster
    no i neet 2 get it rr soon if its 160 170 bhp ill be made up
  8. #158
    Re: Turbo Toaster
    What size is ya turbo?
  9. #159
    prescot, liverpool
    Re: Turbo Toaster
    i think a stage 2 with a bigger turbo elbow, its only slightly bigger than a t2 so maybe better internals, it holds 20 psi well though
  10. #160
    Re: Turbo Toaster
    Well I got 150bhp at 17psi with my T2 so I recon you could expect anythin from 160bhp upto 175ish, porviding your setup is good of course
  11. #161
    prescot, liverpool
    Re: Turbo Toaster
    i think the only thing stopping it wil be the fueling, i have a uprated fuel pump but i aint sure if the petrol geting to the engine is too little, so might get that looked at so its perfect, but theres no problems so maybe its ok. i once had it boostin 30psi on i race see wot wud happen an it was a rocket haha
  12. #162
    Re: Turbo Toaster
    Yeah don't go winding upto 30psi without adjusting the carb or it will go bang.
    When it goes on the dyno make sure the block running the dyno sticks an O2 sensor up ya exhaust and keeps an eye on the fueling
  13. #163
    prescot, liverpool
    Re: Turbo Toaster
    nar 20 is well enuf til i get forge pistons, but it will be workin fine when i fix my starter so gonna jus use this yr 2 drive it an leave it alone i think.
  14. #164
    Non-member RICHIE's Avatar
    Jan 2004
    BEDFORD
    Re: Turbo Toaster
    you dont need forged pistons to run more than 20psi
  15. #165
    Re: Turbo Toaster
    He's right, its more important to get your fueling spot on than it is 2 throw money at parts that tunners tell you, you need
  16. #166
    Non-member markey b's Avatar
    Bury St Edmunds
    Re: Turbo Toaster
    27psi and no forged pistons, steel liners, or posh cam for that matter ....
  17. #167
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: Turbo Toaster
    I'm not sure why people worry about boost, it has no direct relation to how much pressure is in the cylinder. You can have a more powerfull car at only 20psi of boost that has more cylinder pressure.
  18. #168
    Dec 2004
    Aylesbury
    Re: Turbo Toaster
  19. #169
    prescot, liverpool
    Re: Turbo Toaster
    i agree it does depend on the setup of the car but havin them can only help the car when it gets ragged round
  20. #170
    Jan 2004
    BEDFORD
    Re: Turbo Toaster
    [quote=d110rkjste;45024]i agree it does depend on the setup of the car but havin them can only help the car when it gets ragged round[/quote
  21. #171
    Member
    efi-parts.co.uk
    Scoff's Avatar
    Aug 1998
    Liverpool
    Re: Turbo Toaster
    Well, no mate, don't believe the hype. There's alot of experience on here all telling you to save your money It's by far much more important to have the car setup properly. A poor tune will melt forged pistons just as quickly as standard ones.
  22. #172
    Re: Turbo Toaster
    Listern to this man, he knows his stuff, he's like the kung fu master of tunning
  23. #173
    Non-member Adam L's Avatar
    Feb 2003
    SW London
    Re: Turbo Toaster
    Quote Originally Posted by Ben View Post
    It'd probably be an idea to see why the turbo blew, rather than jumping onto something else that may well have the same fate...
  24. #174
    Ruislip
    Re: Turbo Toaster
    Quote Originally Posted by Adam L View Post
    the bearing is completely shot and the turbine shaft has big groves were its over heated. The snap ring and sealing ring have melted completely. also the compressor wheel has contacted the housing and is also fecked. the inline filter looks nice and clear but i want to fit another oil pressure guage as the 1 on the car is a bit suspect. I think thats where the problem may lie. another thought is as it went on national day at mallory just after the long sweeping bend oil has moved away from the pickup and the turbo has been starved.
    will have to arrange a day to bring it over to you for a price on its repair
  25. #175
    Re: Turbo Toaster
    Defo sounds like an oil problem, it didn't run low on oil did it?
  26. #176
    Ruislip
    Re: Turbo Toaster
    No it was always at the maximum level but got to be some problem there as you say. As a standard turbo also went pop 3 track days later (although i was pushing it at 17-18psi)
  27. #177
    Re: Turbo Toaster
    Defo get a decent oil pressure gauge plumbed in, sounds like your not gettin enough oil pressure
    Has the engine been rebuilt at any point?
  28. #178
    Ruislip
    Re: Turbo Toaster
    yes it was re built about a year ago but didnt get a new oil pump. droped the sump about a month ago to cure an oil leak and while i was doing it i removed a main cap to check the bearings, as i thought they may be prematurely failing causing a loss of pressure but they are good as new. will fit a new pressure guage next and see what the readings are.
  29. #179
    Re: Turbo Toaster
    Who built it if ya don't mind asking?
  30. #180
    Jan 2004
    BEDFORD
    Re: Turbo Toaster
    check your getting 45 psi or more at 3500 revs get a few magnets on the bottom of that sump also.
  31. #181
    Re: Turbo Toaster
    ^ good advice
  32. #182
    Ruislip
    Re: Turbo Toaster
    ^ good advice
    built the engine myself, apart from having the pistons attached to the con rods by an engineering company (didnt fancy mucking them up)will check the pressure is holding at 45psi as soon as i can get some time on it will try a couple of magnets on the sump too and see what turns up.
  33. #183
    Re: Turbo Toaster
    I remember seeing that @ Nat day wasn't a pretty sight seeing that VNT in the condition it was 20 mins later you were back on track running a T2
  34. #184
    Bury St Edmunds
    Re: Turbo Toaster
    same here, i was parked infront of it, red one wasn't it? i remember the smoke lol
  35. #185
    Dec 2004
    Aylesbury
    Re: Turbo Toaster
    I was behind it when it went on the track, remember seeing red 5 then it disappeared under a big cloud of smoke
  36. #186
    Bury St Edmunds
    Re: Turbo Toaster
    must have been like following oli testing the EF-aiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiiii
  37. #187
    Re: Turbo Toaster
    Hey I had no problems at national day
  38. #188
    Bury St Edmunds
    Re: Turbo Toaster
    i'm not suprised with a 4k limiter... i was on about the 'last nite of the 5 to this day'... lol
  39. #189
    Ruislip
    Re: Turbo Toaster
    That was me m8 couldnt stand the thought of missing any track time so bought the t2 off a traider and wacked it on with the help of bigdanc.cant let small problems stop the fun
  40. #190
    Re: Turbo Toaster
    Engine update
    Got my spare crank blanaced, reground and some bearings ground to suit, finished painting the block and some of the bits and pieces that bolt to it, so I've started putting it together, gotta get some fresh piston rings then I can finish it and get sorting other things
  41. #191
    Re: Turbo Toaster
    Right, since I started rebuilding my engine I've decided to alter a few bits and do a few things that I have on previous builds, first off I've replaced all the normal bolts that hold all the brackets on the block
    And to go with the new colour scheme I got my spare rocker cover and stripped all the paint off and angle grinded the unused brackets and got going with the red oxide primer
    A quick coat of white primer
    Now I have 1 problem, my original plan was to paint the rocker black with Renault airbrushed in red on the side but now I'm wondering what it'll look like in red all over
  42. #192
    Re: Turbo Toaster
    Update time, first off things have gone a little tits up, namely my pistons aren't exactly round anymore, oh well, good job I've got a new set left from a liner set I bought a year ago.
    Next the rocker cover, I've changed the plan a little, the grouve in the top has now been smooth out and I've stuck on a badge and painted it in, I think I may take it off and get a proper Renault badge though, not sure yet
    To go with the new colour of the block and rocker cover the rest of the ancilieries need attention to fit in with the new scheme, I spotted this ad for sale on ebay from china awhile back but I wasn't sure about the quality cus they were so cheap but a few people on here have bought sets and the've been spot on, as good as the major branded versions so what the hell its only 168quid compared to the 350quid for the branded stuff.
    Overnight parts from Shanghi
    A full set of coolant and breather silicone hoses in lovely black
    And the typical first thing done with new trumpet shaped hoses
    I've also decided to take advantage of the engine being out to replace the old brake master cylinder and brake lines and hoses, a new cyclinder is 40quid from GSF, Lovely , steel braid hoses, 25quid off ebay, sorted, the look on the BMW drivers face when I out brake him, Priceless
  43. #193
    Re: Turbo Toaster
    Defo ditch the badge on the rocker matey looks ****e, apart from that am liking the rest. Keep up the hard work
  44. #194
    Re: Turbo Toaster
    I'm kinder thinkin that aswell but I may get the Renault lettering and put that on there in a Gordini stylee
  45. #195
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    Re: Turbo Toaster
    Looking good Oli, agree with the badge though....its gotta go !!
  46. #196
    Re: Turbo Toaster
    Ok the turbo badge is going
  47. #197
    Bury St Edmunds
    Re: Turbo Toaster
    chrome rocker cover or leave it rusty lol
  48. #198
    North West Area Rep LukeRobbo's Avatar
    Nov 2008
    Cumbria
    Re: Turbo Toaster
    Good work.I think the badge looks ok but i prefer chrome rockers.
  49. #199
    Re: Turbo Toaster
    Chrome is just somit else to keep clean and it doesn't make you go any faster
  50. #200
    Re: Turbo Toaster
    Neither does R E N A U L T
    lol. Ditch that idea mate.
