Page 1 of 3 123 LastLast
Results 1 to 50 of 127
    Non-member MR TURBO's Avatar
    bristol
    Carb service
    Just been quickly browsing the carb service thread, boy it looks a fiddly little job looks like i'm gonna have fun
    burton on trent
    Re: Carb service
    I managed it man. All i did was printed the guide from the articles section. Got a real clean work surface and some vingar to wash parts in , and took my time doing it section by section and highlighting it as i went along. If you are worried about getting any of it back together take a pic.
    Non-member tiff_lee's Avatar
    Glasgow/Lincs
    Re: Carb service
    I'm planning on doing my carb soon as I have no idea what state it is in internally but given how bodged the rest of the car has been no doubt it needs it! Some pretty good guides in the article section I doubt it will be much hassel to do.
    Whats the best way to bring the actual carb housing up like new, a rub down and some silver paint? or bead blast it? naturally all gasket faces and what not would be covered.
    Glasgow/Lincs
    Re: Carb service
    Just got my service kit from the club shop for £2.50, bargain
    bristol
    Re: Carb service
    Glasgow/Lincs
    Re: Carb service
    Nope I stand corrected, just got an email from Clee I used the wrong discount code!
    bristol
    Re: Carb service
    Fcuk me i was gonna say gimme dat code dogg
    What happened to sold as seen
    Member clee's Avatar
    Derbyshire
    Re: Carb service
    Gimme a break guys ...
    Thanks for understanding Lee
    It's feckin complicated Too many little boxes hiding away that need ticking/OR NOT!!! to set up all these fantastic members discounts ........
    bristol
    Re: Carb service
    Quote Originally Posted by clee View Post
    Your doing a fab job buddy keep up the good work
    Aug 2004
    Re: Carb service
    Sack the shop manager i say ....
    bristol
    Re: Carb service
    Quote Originally Posted by Penfold View Post
    Why do you think you could do a better job
    Aug 2004
    Re: Carb service
    Quote Originally Posted by MR TURBO View Post
    Nah Clee is doing a fantastic job, think he will be owed a few drinks come ND!
    Glasgow/Lincs
    Re: Carb service
    Fantastic ain't the word I only had to pay postage! lol
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    Re: Carb service
    stop moaning an start rebuilding them carbs!!!
    bristol
    Re: Carb service
    Taking mine off tomorrow
    Glasgow/Lincs
    Re: Carb service
    Any ideas on how to bring up the carb body like new?
    Derbyshire
    Re: Carb service
    Glasgow/Lincs
    Re: Carb service
    lol cheeky sod, I tried that before on the gearbox while it was out and still looked discoloured and dull, i'm just wonderign how people get theirs looking new after refurbs.
    bristol
    Re: Carb service
    Glasgow/Lincs
    Re: Carb service
    Rain down on me!
    Its funny i've seen that kind of fail happen several times on parade, not nice!
    bristol
    Re: Carb service
    In reference to this on a serious note check ashy's pics in t3 rebuild.....Carb may take similar work??
    Member D4WNO's Avatar
    Jul 2004
    London
    Re: Carb service
    Moving to technical forum
    Non-member scratcher's Avatar
    Milton Keynes - ish
    Re: Carb service
    To clean mine up I used a screwdriver to scrape the worst off, a stiff brush and some wire wool. It doesn't look like new but its clean enough for me
    Markey B done one with a dremmel and it looks amazing.
    bristol
    Re: Carb service
    All is ready i will start shortly.....Bloody eck what a nasty color it is i would definately be a fan of brightening it up a little looks well dull
    bristol
    Re: Carb service
    do i need the 6mm spanner or can i get away with using a 6mm socket??
    THE BAT CAVE
    Re: Carb service
    the carb is made of magnesium isnt it,would that affect what
    you can use to clean it up?
    bristol
    Re: Carb service
    All done and dusted.....Loads of little bits left over tho the moment of truth is coming i'm gonna go refit to the car now......Fingers crossed eh
    bristol
    Re: Carb service
    Just finished tinkering with the carb and it seems to be hunting a little and wont settle down been pissing about with the idle and mixture for ages......sounds like a rough porsche engine
    THE BAT CAVE
    Re: Carb service
    your throttle stop idling speed is satisfatory right?,do that first,
    then turn mixture screw until engine hunts an then turn it in until
    the hunting stops,if your idling speed has now become to high turn
    out your throttle stop.
    try that!!
    bristol
    Re: Carb service
    try that!!
    it seems the grp a what was on there was better on idle etc but just hesitated on boost sometimes......My mixture screw maybe fooked as it seems to make no difference when adjusting...may swap the bottom bit with the green seals and mixture screw over.....also the accelerator pump how far must that be screwed back on??
    THE BAT CAVE
    Re: Carb service
    think a new mixture screw would be wise as far as accelerater pump goes im not
    sure,someone else will have to point you right there,id like to know to because
    soon i will be rebuilding a carb to
    Glasgow/Lincs
    Re: Carb service
    So no mixture screw in the service kit? Does it just have a small o-ring retained on the end or something?
    THE BAT CAVE
    Re: Carb service
    there is a small o-ring
    bristol
    Re: Carb service
    well i have taken the whole carb off and will have a good little look around
    bristol
    Re: Carb service
    on the mixture screw is it supposed to have a point on the end or flat??
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    Re: Carb service
    should have a point on the end mate...i bet yours has snapped off in the base of the carb, very common to happen
    bristol
    Re: Carb service
    Quote Originally Posted by Kris M View Post
    The little cnut yup sure has i'll have to hunt one out
    Apr 2006
    Swindon
    Re: Carb service
    yeah, just tap it out with something very thin / strong and get yourself a new mixture screw
    Non-member RICHIE's Avatar
    Jan 2004
    BEDFORD
    Re: Carb service
    get it vapour blasted as its not harsh it will come up nice and new then get it laquered to keep it nice
    bristol
    Re: Carb service
    any one got a mixture screw??
  41. #41
    Glasgow/Lincs
    Re: Carb service
    Cool there is a place down the road from me that does vapour blasting
    lacquer? as in normal spray paint lacquer?
  42. #42
    THE BAT CAVE
    Re: Carb service
    super cheap from renault buddy
  43. #43
    bristol
    Re: Carb service
    Tried it again starts then dies and doesn't start again WTF is the problem
  44. #44
    Tipton
    Re: Carb service
    have you gt the black rubber O ring on the mixture screw?
  45. #45
    bristol
    Re: Carb service
    yep all is on there but no go.....Just changed back to the other carb and all is fine again....Now my radiator fan ain't working instead
  46. #46
    Tipton
    Re: Carb service
    trapped air, broken relay, wires popped out of the fan switch? or even a broken fan switch.
  47. #47
    Oct 2004
    Somerset
    Re: Carb service
    bets on it being the mixture screw....
  48. #48
    THE BAT CAVE
    Re: Carb service
    you got a new mixture screw mr ??
  49. #49
    bristol
    Re: Carb service
    Picked up a mixture screw from renault today all sounds ok now on tick over even tho i did want to swap carbs oh well.....but the gas pedal now seems a little stiff and resistant to push down any ideas?? haven't driven it yet tho as for the fan the lil barsteward was always a liitle noisey but worked wonder if it has popped its clogs
  50. #50
    bristol
    Re: Carb service
    What does this spring do??? Is there a recommended setting when screwing back on???
