Results 1 to 6 of 6
    Non-member J$£5GTT's Avatar
    THE BAT CAVE
    piston liners
    how much of a shoulder is to much to salvage a liner,
    or can they be honed out an use a larger diameter ring?
    Mar 2004
    Salford (manchester)
    Re: piston liners
    You could messure them either with a 3 way bore mic or drop a ring in and messure gaps... You can de glaze them with a self honing tool to help clean them up... If you start re boring the liners will just get to thin and i dont think oversize pistons are available... could be wrong.. but at least you could make the perfect P2W clearance to match your build.
    THE BAT CAVE
    Re: piston liners
    the particular pistons an liners i have are just spares an was just going
    to see if they are re-workable,the self honing tool i have seen,it has a
    setting so you dont over work the liner right?
    Mar 2004
    Re: piston liners
    Pre-load on a spring i think, i havnt used mine in a long time... just keep them as spares...
    THE BAT CAVE
    Re: piston liners
    Non-member Adam 005's Avatar
    Dorset
    Re: piston liners
    I have never come across liners to worn not to be reused.
