Results 1 to 7 of 7
    burton on trent
    possible rear beam problems
    ok, basically its a little strange, ive had 3 sets of wheels on my car so far, 13s, 15 inch turbines, and 14 inch steel wheels.
    I have a problem where around once every 20 mins a loud humming/vibration shakes the car , and then goes away, its like a wheel severly rubbing but i cant work out what it is. This happens at any speed, usally driving straight on smooth roads.
    The only thing i thought is that maybe the rear beam is on some kind bushes that have began to fail , allowing for movement.
    Any ideas folks .
    Re: possible rear beam problems
    Have u checked the rear wheel bearings, there pressed into the rear discs
    burton on trent
    hmm not yet, is that a case of jacking the rear of the car up and then checking for any play .
    Look-Out Kris M's Avatar
    Apr 2006
    Swindon
    yup
    After that check the bolts the hold the rear dampers on, these should have thread lock on so the don't work loose but ya never know
    burton on trent
    sweet, thanks for the suggestions , i will let you know my findings, kenobi seems to think i have a bent rear beam, maybe that is the case.
    What u been doing to do that, shagging a fat bird in the back lol
