Results 1 to 17 of 17
    Non-member car.crash's Avatar
    Aug 2006
    285 mm discs
    what cars do the 285mm discs come from for the big brake upgrade, caliper extenders i already have, will i need the matching pads or do i use my originals.
    Re: 285 mm discs
    The pads are just standard R5 GTT caliper fitment (So nothing bigger) just what ever brand you fancy or re-use your originals if loads of pad left, The 285 discs I think are off a Renault 21 TX or something like that which have the 4 x 100 fitment like the R5. I think Ricardo got some off a 21 for the white R5 had which he has recently sold to shopboy.
    Jun 2006
    Bournemouth
    Re: 285 mm discs
    renault 21 tx is the correct answer
    Non-member Tiny Tim's Avatar
    Oct 1999
    Bournemouth
    Re: 285 mm discs
    TXi.... Just make sure its the 4 stud (4X100PCD) as most of the 21 range are 5 stud.
    Aug 2006
    Re: 285 mm discs
    thanks alot
    Non-member Billy-G's Avatar
    Feb 2002
    It changes. A lot.
    Re: 285 mm discs
    21 TXE isn't it?
    Oct 1999
    Bournemouth
    Re: 285 mm discs
    Quote Originally Posted by Billy-G View Post
    21 TXE isn't it?
    Errr.... Oh. My brains confused now. I MAY be getting mixed up with the enlarged throttle body mod for 21 turbos.. thats deffinately off a TXi.
    Ricardo's our man...
    Re: 285 mm discs
    I think you mean Ricardo's your man
    Oct 1999
    Bournemouth
    Re: 285 mm discs
    Feb 2002
    It changes. A lot.
    Re: 285 mm discs
    I think Mart's Failboat has docked at Timmy's dock indeed
    Non-member Mart's Avatar
    May 1996
    Pie & mash shop
    Re: 285 mm discs
    Non-member Frix's Avatar
    Re: 285 mm discs
    so do you use standard calipers just add with the extenders?
    Re: 285 mm discs
    Quote Originally Posted by Frix View Post
    Non-member Ricardo's Avatar
    Re: 285 mm discs
    Renault 21 TXi 4 stud, i paid £65 for a pair from Unipart.
    Google Brakes International for prices, obviously 285mm but mention this as they also do a 265mm disc for a TXi too
    That's the beauty of the caliper extender, you get an extra 47mm in diameter and still utilise the GTT calipers and pads. They just bolt onto the hub and the caliper bolts to the extender, easy
    Oct 1999
    Bournemouth
    Re: 285 mm discs
    Your man doing another set anytime Rich?
    Re: 285 mm discs
    Apologies Timski, been right off the boil for a while. I need to find the hard copies of the drawings to get them done again
    Oct 1999
    Bournemouth
    Re: 285 mm discs
    No, no worrie mate... just stick me down for a set as and when.
