Results 1 to 4 of 4
    burton on trent
    ive sprung a oil leak
    Well rolled on the drive tonight and found a unhealthy trail of oil, it appears there is a major leak from around the front of the sump where the 90° rubber bend is , or its from the bottom of the turbo feed union where i have my mechanical oil presure gauge pumbed in , either way when you put your hand up behind the bumper you get a good blast of hot oil spray.
    Non-member mightymanx's Avatar
    isle of man
    Re: ive sprung a oil leak
    Quote Originally Posted by djinuk View Post
    i had a very bad oil leak there on this gtt.
    turned out it was the oil sender switch
    bracknell
    Damian try finding the leack it most prob just a split hosery or sommat
    burton on trent
    i found it, turned out to be which i plumbed in my mechanical oil presssure feed *bottom of the turbo union* all sorted
